#16
Re: Window clips
At least it wasn't the CAT convertor this time.
#17
Re: Window clips
LOl, true.. I've never replaced the thermostat and I have over 128k.. Should I replace it?
#18
Re: Window clips
#19
Re: Window clips
Well I replaced the sensor for the temp gaugeand GOT IT INSPECTED!!!!!!!!!!!! Thank Jesus... But the thermostat doesn't look very esy to get to.. The intake where the cables for the gas pedal line is in the way and honestly I'm tired and broke from getting this POS fixed... I'll do like I always do and wait till it F's up... Thanks again for your help bnaylor.. If anyone wants 2 window clips for free let me know...
#20
Re: Window clips
I was able to remove the white broken window clips today off my daughters 2002 Alero. They were epoxied on and very hard to get off. I used a jigsaw with a fine blade and was able to remove both of them with 3 cuts each. First I CAREFULLY cut the bottom off (about 1/4 inch) cutting as close to the glass as I dared. Then I used the saw to slice the clip off each side of the window. I then used a sharp box-cutter knife to finish scaping the rest off the window and clean up the epoxy. I was able to get both clips off without breaking or scratching the window. Be careful in buying new clips. I got a new design - metal clips, that do not fit correctly and had to do some more jury-rigging to make them work.
#21
Re: Window clips
Thanks for contributing and sharing your experience. However, this is an old thread so it has been closed.
