#16
Re: 94 Blazer Gasket Issues
So I was removing my alternator and well the ring holding the bolt broke:
![]() Any suggestions on how to fix this?? could I use epoxy or something like that? Thanks |
#17
You could take and have it welded. I doubt expoy would hold for long.
![]() 1996 Blazer LT 4 Door, 4x4, 4.3L Vin W. |
#18
You could try and get it welded or check out your local junk yard and see if you can pickup a whole new bracket and just replace it.
#19
I have my left exhaust manifold removed.. but its suck inside the car. There is a circular piece just above the exhaust manifold but below the valve covers that is blocking me from removing it. It had a white electrical connection attached to it that I removed by squeezing and pulling it off. It kinda looks like a big spark plug.
do I need to remove this?? and how? |
#20
ok so i just removed the valve covers and they are caked with yellow crap! it looks like cheesecake in there.. im assuming thats bad. What does that mean?
Secondly, what can I use to clean all these parts.. lacquer thinner? what do you guys use? thanks. |
#25
I just want everything clean when i put it back together. |
#27
Ok now in order to get to the right head gasket I need to remove the air conditioning compressor.. It says the system is under high pressure and I should discharge it.. can I do this myself?
There isnt anyway to keep the A/C charged while I get to the heads? |
#30
Yoiu can leave the air cond freon lines/hoses on the air cond compresser.
Just unbolt compresser from its mounting bracket and lay it over to the side. Sometimes you can use a little wire to tie it or hold it over out of the road. MT
