Old 01-26-2006, 09:20 PM
675datsun's Avatar
675datsun 675datsun is offline
Re: COMPLETED: Tamiya '71 Skyline GT-R
I really like the ignition wiring, what size/type of wiring did you use and what is your method?
My wiring jobs look relatively horrible and I always wonder if I should start wiring from the distributor to the head/valve cover, or from the head/valve cover back to the distributor.
The stacks do look great on there, and this is the first time I've seen the GT-R without a rear spolier...looks good!
Old 01-26-2006, 10:42 PM
tigeraid's Avatar
tigeraid tigeraid is offline
Authorized Vendor
Originally Posted by mikemechanic
Looks good John. Yes I did miss your reply, lost track of the progress thread. Thanks, I did sit down and painted the grille finally. Mine should be done soon. I went a little different route than yours. Hopefully some pics next week.
Cool.
Old 01-26-2006, 10:44 PM
tigeraid's Avatar
Authorized Vendor
Great question. I use actual "ignition wire" which can be bought from a variety of modelling suppliers. So far the only non-modelling source I've found for it is inside phone cords, so if you're real cheap, you can cut one up and use those--I'd just rather have em in a drawer ready to go. I ALWAYS wire the distributor first. If it's a really tiny, poorly detailed distributor, I'll twist all 8 wires together, solder them, and then drill a single hole in the middle of the distributor. I stick the soldered end in and then splay the wires out to look like they're 8 seperate terminals.
In the Skyline's case, I drilled 6 seperate holes with a pin vice, because the distributor was large enough to do that. 8 holes for a V8 on this distributor woulda been impossible though, I think.
Old 01-27-2006, 04:02 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
I found the supplied distributoron this kit was a bit too small to wire, so I made my own from Aluminium, which you can see above.
Steve a.k.a. Hiroboy
Old 01-27-2006, 01:04 PM
675datsun's Avatar
Thanks for the advice John, it really helps me!!
Old 01-27-2006, 02:14 PM
Andy Jones's Avatar
Andy Jones Andy Jones is offline
I build what I build
Excellent build - engine bay looks epecially impressive - you & Steve are tempting me to order one.
Cheers
Andy
Old 01-27-2006, 03:51 PM
quadzero's Avatar
quadzero quadzero is offline
another fine build and excellent subject. very typical of your work. i would love the 1:1 car, wohooo!
