Go Back   Automotive Forums Car Chat > Toyota > Sienna
Old 01-23-2005, 09:47 PM
Turkalifam Turkalifam is offline
Biggie,
The instructions worked perfectly on my 01 Sienna. Completed in two attemps.
Thanks,
Ken
Old 02-02-2005, 11:13 AM
HeyTomToyota HeyTomToyota is offline
Re: Help needed in programming Keyless remote for 2002 Sienna
I have a 2003 Sequoia (not Sienna), but I need to reprogram my two remotes. I tried this Sienna proceedure, but after the second set of 5 cycle on the locks, I did not get the automatic power lock cycle.
Anybody know what the procedure is for a 2003 Sequoia? It is the factory system.
Tom
Old 02-04-2005, 09:24 PM
altosreseller altosreseller is offline
succsess!!!!!!!!!!!!!!!!!!!!!!!!
Did it done it made it work Thank you all Phil in Ca
Old 02-04-2005, 09:26 PM
Re: Re: Help needed in programming Keyless remote for 2002 Sienna
Tom
I programmed my 2 new remotes, and then my old ones stopped working. Sure enough, I didn't read the instructions properly. I had to program those 2 and my old 2 all together. They all work perfectly now.
1. Insert the key into the ignition (don't turn it) and pull it out
2. perform 5 lock/unlock cycles starting with lock.
3. Close, then open, the driver's door.
4. perform 5 lock/unlock cycles starting with lock, as you did previously
5. Turn the ignition to "ON" (as far as you can go without cranking your engine), then back to "OFF".
6. Again, turn the ignition to "ON" (as far as you can go without cranking your engine), then back to "OFF".
7. Remove the key from the ignition.
a)Within 3 seconds, the power door locks should cycle (lock then unlock) automatically, indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
Perform these steps within 40 seconds:
a) Press the lock and unlock buttons on the transmitter (the remote) simultaneously for 1 second.
b)Immediately after letting go of the lock and unlock buttons, hit the lock button by itself and hold it for 2 seconds. Within 3 seconds, the door locks should cycle (lock then unlock) once indicating successful programming. If the door locks don't cycle, or cycle twice, repeat steps 7a,b, as this means the remote has not been accepted.
c) Repeat steps 7a and 7b for each transmitter that will operate the vehicle, including any EXTRA old transmitters. BEFORE YOU CLOSE THE DOOR!!!!!
Close driver's door.
Old 12-09-2005, 01:12 PM
soccerman600 soccerman600 is offline
Wink Re: Help needed in programming Keyless remote for 2002 Sienna
Thanks Biggie!!! This worked for my 2001 Sienna XLE with dual power doors.
Originally Posted by Big Yellow Monkey
I bought some remotes off of ebay for my 03 sienna, and they came with programming instructions. I figure I'll share them with y'all... The instructions are as follows:
1. Start with the following conditions:
a) Key is out of the ignition
b) Driver door is open (all other doors are closed)
c) Driver door is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a)Using the power lock/unlock switch on the driver's door (with the driver's door still open and unlocked), perform 5 lock/unlock cycles starting with lock. A lock/unlock cycle consists of pressing the power lock switch, followed by pressing the power unlock switch on the driver's door panel. Use an even pace and try to go relatively fast.
b)Close, then open, the driver's door.
4. Perform these steps within 40 seconds:
a) Using the power lock/unlock switch on the driver's door, perform 5 lock/unlock cycles starting with lock, as you did previously.
b) Turn the ignition to "ON" (as far as you can go without cranking your engine), then back to "OFF".
c) Again, turn the ignition to "ON" (as far as you can go without cranking your engine), then back to "OFF".
d) Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (lock then unlock) automatically, indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
b) Immediately after letting go of the lock and unlock buttons, hit the lock button by itself and hold it for 2 seconds. Within 3 seconds, the door locks should cycle (lock then unlock) once indicating successful programming. If the door locks don't cycle, or cycle twice, repeat steps 6a and 6b, as this means the remote has not been accepted.
c) Repeat steps 6a and 6b for each transmitter that will operate the vehicle, including any old transmitters.
7. Close driver's door.
There ya go. Just a couple pointers.
First off, notice the bold in step 6 c). You have to repeat 6 a) and b) for EVERY remote, both your old ones that were already working, and your new one(s). And you have to do it before closing the driver's door in step 7.
Second, don't test your remotes until you've completed step 7. Then go ahead and test all of them. If you press one of the buttons on the remotes before having completed everything and closing the driver's door, the programming will not be successful.
Spread these instructions around. I remember looking for them and not being able to find em anywhere.
Oh, and enjoy!
-Biggie!
Old 10-28-2008, 04:38 PM
sienna racer sienna racer is offline
Thanks Big Yellow Monkey
Just used this for my Toyota Sienna LE 2000 with factory remotes.
WORKED GREAT ON FIRST TRY with all the keyes!
Old 05-27-2009, 11:42 AM
Salocinbake Salocinbake is offline
Big yellow monkey's instructions, work to program my keyless remote for a Sienna 2002 CE.
Thanks
Old 06-19-2009, 09:56 PM
sandyman sandyman is offline
I have a 2002 Sienna Symphony with (1) power sliding door (passenger side). Any solid method for this model w/ the one power slider? The remotes just quit suddenly. I replaced the battery in each unit with no success. Help!!!
Old 03-09-2014, 01:22 PM
jerryhackett jerryhackett is offline
I have a 2002 Toyota Sienna LE and the directions from "schwaboys" are the ONLY ones that worked. all of the others would not put my car into programming mode, and the directions from schwaboys worked first time!!! It was awesome, especially after diddling around with the others for a couple of hours.
Dealer says new computer needed to program keyless remote, I think they are wrong.. hoover101 Sequoia 2 03-16-2010 11:17 PM
96 Camry CSI Program Keyless Remote JeanC Camry/Camry Hybrid/Vista 1 07-15-2009 12:28 PM
Programming keyless remote for 2002 Grand Prix GTP mad_max Grand Prix 4 04-15-2007 11:00 AM
Need help programming keyless remote for 99 T&C mikeDFW Caravan | Voyager 4 01-15-2005 02:33 AM
Need instructions for programming keyless remote for '94 G/Caravan Yankeedrummer Caravan | Voyager 0 08-01-2003 01:45 PM
