#16
Re: Highway vibration
I really want to get this vibration fixed, but I don't want to pay for one thing after another and the problem isn't solved. I can hear a sound coming from the front left wheel when driving, though I can only hear it when its reflected off an object. It gets louder at one point in the wheel's rotation and quiets at the opposite side of the wheel. It sounds like something rubbing, like brakes when they are freshly applied to wet discs. Vibration is sometimes present at lower speeds, such as 30 mph, but mainly comes in at speeds above 45 mph. It seems to vibrate less around 80-90, though. The vibration is mostly felt through the steering wheel in the form of a slight twitch left-right. It is rarely felt on roads with bumps in them, but rather smooth pavement. When the vibration is present and I apply the brakes, the whole front end of the car shimmies back and forth. In addition, the steering wheel twitches a lot, like an inch, left and right, many times per second. I have done the following: tire balance (3 months ago), rotation, 4 wheel alignment, outer tie rod end replacement, rear rotors (helped somewhat), and an upper control arm bushing replacement. I'm wondering if I just need to rebalance the front tires or replace the front rotors or maybe the inner tie rod-ends. Has anybody had this before? I really don't want to spend much more money, as what I 've mentioned already totals up to over $700 and that's a lot to a senior in high school!
#17
Is someone going to help? I went yesterday and had all 4 tires balanced again. Some forms of the vibration are gone, but the steering vibration has become constant and gets worse with the brakes being applied. Am I facing an intermediate steering shaft problem, or maybe bad rotors? Maybe bad tires? At the tire shop, they pumped the tires to something like 40 psi (I didn't check - that's what they told me), claiming the recommended 31 psi is too low and causes too much wear on the outsides of the tires. HELP!
#18
Update: Vibration is still annoying as hell, but now there seems to be something else. I can only notice it with the windows open and particularly when there is something to reflect the sound back from the car. Only when I am turning to the right (typically on freeway ramps, around 40mph) there is a clicking sound coming from the front drivers side wheel. It seems to click once with each wheel rotation. As soon as I point the wheel straight, the sound is gone. It only does it when the wheel is turned past a certain point to the right. The sound seems to have something to do with the brakes hitting the wheel? Cracked wheel perhaps? I just had my tires balanced and they said all the wheels were fine.
#19
This vibration is getting worse! I seem to be the only one posting. Has anyone had this before? In the rain, it is awful, as the front end of the car is "shimmying" and makes a loss of control much easier - I've hydroplaned in very little water many times now. Could this be my intermediate steering shaft? I know how that would feel when it's going bad - a clunking/loosness in the steering at slow speeds, but I don't have that.
#20
It sounds like you have a couple of things happening. the steering wheel twitching could very well be the intermediates steering shaft. I've heard there is a kit you cnapurchase to "fix" it. I learned on another forum that you cna lube the shaft form inside under the steering wheel. Use lithium grease, pull donw the rubber sheath as far as you can, spary as much greas as you can get into the connection. Makes a big difference driving.
If you are hearing noises when the wheel is turned, you could very well need a new wheel bearing. At my last inspection the mechanic mentioned I should get mine changed in a few months. I woudl check that out since you tried everythign else. |
#21
Now, the clicking sound can be heard from both front wheels. When I turn right, the sound is heard in the left wheel and when I turn left, the sound is heard from the right wheel. Also, when I am braking moderately to heavy, I can hear the sound, too. It seems to click once per tire revolution. I am going to be replacing my tires very soon with Goodyear Assurance Triple Treads, so I'll see if the existing tires are part of the problem. I'll also be replacing my front rotors with the heavy duty set (12"). I would like to lube my intermediate steering shaft, but am a little nervous. If someone could post pictures and detailed instructions, that'd be great.
#22
Replacing the tires and brake rotors is probably where I would go first, too. (In some cases CV joints can make clunking sounds too. An experienced tech could identify this sound rather quickly). Another thing to check might be the center caps on the wheels. If they were loose for some reason they may make noise as well. Stones, nails, or screws in the tires could make noise too.
The steering shaft issue is mostly a light, soft clunking type of sound - actually will sound like it's in the column area itself - inside the car. It won't really make the steering feel loose, it's just kind of an irritating sound/feel. (My wife never even noticed it). Being a mechanic, I picked up on it right away, and after having the car for about 10 months I finally got off my ass and fixed it. Here's the first 2 pages of the instructions for the steering shaft repair.... I didn't remove the shaft from the car totally. I just unhooked the shaft from the top and did it in the car. KEEP IN MIND, you don't want the steering wheel to move very far (left or right) once the shaft is disconnected or you will damage the spiral spring assembly for the air bag system. I used some bungee cords and secured the steering wheel to the right door somehow to keep it from moving. Also, it's a real bear getting the top of the shaft back on. ![]()
#23
I just replaced my tires with Goodyear TripleTread Assurances and what a difference! No more ride vibration! They're very grippy, quiet, and have a long tread-life. I still have a front end shimmy when braking at high speeds and the rotors make nasty noises at moderate braking, so I'm going to replace front rotors and possibly pads w/Napa's (cause they're muchhhhhh cheaper than GM's).
#24
Autozone has front rotors for $18.99 a piece. If there's enough meat on the rotors you could have them turned. I walked into a CarQuest with my 2 front rotors and they turned them for $20. I had to replace the rears cuz they were below wear limit even before turning them.
#25
Okay. I broke down and replaced the front rotors and pads (200 something at the stealership). The brakes are smooth and strong now, but the freakin steering vibration is back! The wheel vibrates most between 40mph and 80mph. The vibration is in the form of a rapid left-to-right twitch. Once I go over 85, it goes away mostly until I hit 100. I don't want to drive 85 mph just to get rid of a vibration and get killed! I know my tires are balanced (road force balance on brand new tires a week ago today) and all my brakes are good (front rotors and pads done on wednesday, rear ones last month) and new outer tie-rod ends last month. My alignment might be out, but I doubt it, as I had a 4-wheel alignment a few weeks ago. Does anyone have any suggestions? I griped to the dealer and they will be looking at it next week (eeeeeeek). I hope it is nothing serious!
#26
This is not what it feels like. Besides, I have an 01. I will try to explain it a little better. When I am driving, particularly between 40-75 mph, the steering wheel is usually moving back and forth (in a left-right direction) as though there is a wheel that is shimmying. As I turn, it feels very notchy, though not high effort. It's like I turn one tooth on a gear at a time without any grease, but I don't think it's coming from the rack. I am wondering if I have a bad bearing or maybe a loose tie-rod end somewhere that's allowing a wheel to wobble. Other than that, I'm ready to let the dealer diagnose it (I must have gone out of my mind).
#29
To me, it still sounds like a tire/balance issue, although it sounds like you've very recently covered those bases. About the only thing you could do yourself at this point is try rotating the front tires to the rear to see if one of the fronts went out of balance or threw a weight off or something.
If you take it to a dealer insist on riding with the technician before he works on the car to show him exactly what it is doing. Also make sure the tech uses a torque wrench when installing the wheels to avoid warping the rotors. |
#30
Could the "clicking" noise coming from near the wheels while turning indicate a bad CV joint?
