Go Back   Automotive Forums .com Car Chat > Mercury > Villager
Old 03-03-2006, 12:16 PM   #16
Eddie45
Re: Passenger low beam out.
Mine, a '99 has the high/low beam on the same turn signal switch stalk. My high beam wouldn't work all the time and low beam would go out without warning and sometimes would start to flicker. Eventually, my turn signals wouldn't work half the time.
I though this switch was the culprit. Ordered it and waited for it to arrive, it never arrived and when I contacted Advance-auto they said they never had it in the first place and admitted should have told me so before placing an order. Next I called the dealer and the guy told me the price is around $90 and they have it in stock... went after work to pick up, only to be told they didn't really have it and can order it the following day. I placed the order and went home from there... I decided to take the switch out and take it apart. It had several small pieces inside (all looked brand new) and a quick look at them I found that when they greased the parts upon manufacturing it, they went overboard and there was grease on many copper parts that got hardened and did not provide proper contact. I cleaned them with electrical contact solvent and tooth brush and put them back together and that solved everything... now it's as good as new and I didn't have to spend $90 for nothing.
I hope this information helps someone with similar problems.
Eddie
Eddie45 is offline   Reply With Quote
Old 05-30-2007, 01:14 AM   #17
bensonchuong
Talking Re: Passenger low beam out.
Hello People
I had the same issue, the problem is the day time light module located above the passenger side strut. if you want you can replace that, I just went to the junk yard. Thoes modules like to die I've had a few diferent ones go on me (light, wipers). The second choice is the run a ground from the light harness to the body pinpoint the ground (shoud be green) and stick a piece of wire in to the back of the light socket, then attach that to the body. The module controls the ground, like almost all the things in this vehicle (not intellegent). You cannot unplug the module though because you driver light will go out. Hope this helps, reply if you have questions
bensonchuong is offline   Reply With Quote
