#16
Re: EGR Connecting Tube Mystery
Jack of all trades...Master of none! Could someone please fix my Instant Email Notification? Please get back to us with your fix! Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
#17
check for vacum leaks around the things you replaced have you replaced the dpfe also check engine light on?
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs ![]() also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon |
#18
Just a quick little tip here, If you are suspicious of a possible vacume leak then you can use WD40 or even Starting fluid (although I prefer the WD40 because it's less volitile) with the engine running and the extension tube on the can of WD attached spray a small amount in the area that is suspect and if the engine raises in idle or smothens out then you have a vacume leak there.
The reason this works is that the fluid briefly fills the gap where the vacume leak is, and you won't always hear a vacume leak but this method is about the easiest and least expensive way to find a possible leak. Marco Sr. |
