Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 01-06-2006, 12:07 PM
WPAGEJR WPAGEJR is offline
Re: Re: 95 Neon
Originally Posted by 99 Neon R/T
If the head is off then pour a little water around the valve seats.
I WILL TRY THAT. ALSO IT SEEMS ALL THE EXHAUST VALVES ARE STUCK OPEN. I REMOVED THE ROCKER ARMS SO THAT THE SPRING IS EXPOSED. AND ALL THE EXHAUST VALVES ARE OPEN. ALSO ON THE INTAKE VALES, THEY APPEAR TO BE BURNT. LIKE A WHITE CRUST AROUND THEM.
Old 01-07-2006, 08:50 AM
Re: Re: 95 Neon
GOT THE VALVES OUT. ALL OF THE INTAKE VALVES ARE BENT AT LIKE A 35 DEGREE ANGLE. THE EXHAUST VALVES LOOK A LITTLE OFF, SO IM GONNA REPLACE ALL OF THEM TODAY.
Old 01-07-2006, 10:27 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Re: Re: 95 Neon
That is usually the result of the timing belt snapping or skipping a few teeth. After you do the valves, the engine should be good to go for another 100,000 miles
Old 01-07-2006, 10:29 AM
Re: Re: Re: Re: 95 Neon
THE TIMING BELT WAS ACTUALLY LIKE WOOL. JUST WADS OF WOOL. NO BELT EXISTED WHEN I GOT THE CAR. PRETTY BAD.
Old 01-07-2006, 12:17 PM
maykelcj's Avatar
maykelcj maykelcj is offline
Re: Re: Re: Re: Re: 95 Neon
That happened to me once!!! I had to replace the valves. the cause for this in my neon was that the tenssioner broke, so get one of those wile you are at it.
12:1 all motor neon, sold
got me a CRX HF and put a DOHC ZC on it.
Old 01-08-2006, 12:58 AM
Re: Re: Re: Re: Re: Re: 95 Neon
He did change the tensioner also, but I don't think he mentioned the water pump. That should be changed at the same time as well.
Old 01-11-2006, 01:50 PM
Angry
Okay I Have Rebuilt The Head. Car Starts Fine Then When I Went To Put It In Reverse It Went Forward. Now When I Put It In Gear It Does Nothing. I Checked The Fluid. Way Too Low. So I Added Some. Still Nothing. If I Rev It High Enough It Inches Forward. Any Ideas?
Old 01-13-2006, 12:54 AM
99 Neon R/T 99 Neon R/T is offline
Re: 95 Neon
Did tou remove the transmission?If so then did you prefill the torque converter?That in my experience is usually the problem.
If it aint broke fix it till it is.
Old 01-13-2006, 08:57 AM
Re: Re: 95 Neon
no i never removed the transmission. the car was sitting for a good 2-3 months before i got it from a friend. im thinking a good trans flush. i will try that later.
Old 01-13-2006, 10:19 AM
Re: Re: Re: 95 Neon
That would be a good idea
