Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 08-01-2002, 11:37 AM
Tominos Tominos is offline
it is because if you face it the other way, the turbine(exhaust side would be too big) and it won't clear the block. i am currently in final stages of my project and have experienced the problem. still, my wastegate on my turbo will not clear the block, i need to make adapter plate that positions turbo out about 2 inches from the block so it would clear my power steering and motor mount bracket. instead of the hole in the adapter plate, it has to be a big angle cut hole, don't know if that will flow too good. oh well.
Old 08-01-2002, 07:16 PM
pvang31019 pvang31019 is offline
what we did was grind down the motor mount a little....
I can get you a manifold that is angled out to clear the block, but cannot use with AC
Old 08-22-2002, 05:27 PM
black 00 civic dx black 00 civic dx is offline
Send a message via AIM to black 00 civic dx
hey guyys, im looking to go the turbo route on my 00 civic single cam non vtec, and been putting together a setup with a guy from turbomanifolds.com and he's recommending a td-05 turbo ($250) for me, for full driveability and streetable, anyone else have opinions on what kind of turbo i should run? the td-05 gets full boost at 2500-3000 rpm, anyone know of anything around there , i only plan on running 5-7 psi.
ryan
