Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-02-2006, 12:38 AM
XeVeNskyLiNE's Avatar
XeVeNskyLiNE XeVeNskyLiNE is offline
Turbo makes me emo!
Send a message via AIM to XeVeNskyLiNE
Re: Re: Re: Re: Car Belt Squeels
Originally Posted by Nayr747
Isn't is bad to put oil on the belts? My belts squeel too when it's warming up, but then it goes away after a couple mins. How do you know how much to tighten them?
Btw, does anyone else's brakes squeel *really* bad the first couple times you use them when it's real cold out?
Meeeee. The new belt doesn't squeek at all when I'm sitting there. But once I turn the wheel about 1 1/2 - 2 times it fuckin screams like a banshee. So I just sit there and rev a 2k to warm things up.
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv
Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM
Old 01-02-2006, 12:47 AM
Spyderman96's Avatar
Spyderman96 Spyderman96 is offline
Send a message via AIM to Spyderman96 Send a message via MSN to Spyderman96 Send a message via Yahoo to Spyderman96
Re: Re: Re: Re: Re: Car Belt Squeels
So oil on the belts is a bad thing? Cause It doesn't squeel at all now
I got my right hand and my left hand, I can smack you with both. -De Niro
1996 Mitsubishi Eclipes GS Syder 2.4liter engine - Stock
Old 01-02-2006, 12:50 AM
Turbo makes me emo!
actaully I haven't tried it. Might give it a try when I get home.
Old 01-02-2006, 02:27 AM
Nayr747's Avatar
Nayr747 Nayr747 is offline
Re: Re: Re: Re: Re: Re: Car Belt Squeels
When Jake was putting his new engine in someone said "I hope you made sure not to get anything on the belts." And jake said "no, I'm always really careful about that."
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 01-02-2006, 10:15 AM
Tell me how it goes, Cause my squeeling was terrible. I would be driving it for an hour and the squeeling would start when I stopped at a light. That Oil did the trick
Old 01-02-2006, 06:46 PM
Nayr747's Avatar
I still don't understand how you know how much to tighten it. To check the tension you need a tension gauge. And I think those are pretty expensive.
Old 01-02-2006, 08:47 PM
violent31601's Avatar
violent31601 violent31601 is offline
Send a message via AIM to violent31601
i don't think you should put oil on the belts...even belt dressing isn't good for it
Old 01-02-2006, 11:18 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Originally Posted by MexRocket
i wish... everytime i see your body i feel all homoerotic
I thought we had gone through this shit once before...STFU about this garbage, your only making yourself look like a retard.
As for the question, Sphyder's list was right on, as usual.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 01-02-2006, 11:19 PM
Turbo makes me emo!
I used to tighten till I couldn't turn it anymore. Now that the bolt shitted on me, I just used a buddy and a crowbar.
Old 01-05-2006, 09:40 AM
***Here's the latest update***...
The squeeling came back!!!
Here's a new thing im noticing now.. Since I got my new waterpump installed, it doesn't leak anymore. However, if im in 2nd gear, if im not holding the shift, it will slip out of 2nd gear into N.
You think this has something to do with the machanic when he installed the waterpump or is it the oil i put on the belts to stop the squeeling???
Old 01-05-2006, 11:50 AM
MexRocket's Avatar
MexRocket MexRocket is offline
uhhh thats really weird... lol i would just check all the nuts and bolts to make sure they're tight... i cant think of anything else if you got a new water pump... how old is your altenator?
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 01-05-2006, 12:47 PM
2006 ECLIPSE GT 2006 ECLIPSE GT is offline
i don't think your shifter slipping out of 2nd gear has anything to do with your waterpump...that sounds like a tranny or clutch problem.
Silver 2006 Eclipse GT
came with factory body kit, everything else is stock.
Green 1996 Eclipse GS (my first baby)
Greddy headers and catback, Injen intake, MSD ingnition coil, MSD 8.5 wires, OBX crank pulley, short shifter, Blitz body kit, 18" rims, projector headlights, halo reverse gauges, and some kind of racing seats.
Gray 2004 Lancer Ralliart
Bone stock
Black 1997 Eclipse GST
SOLD
Old 01-05-2006, 12:56 PM
do u know what belt is squeeling, the ps or alt?
one of the ways u can tell if its the ps belt...turn on your car, have someone turn the wheel and look at the ps belt to if its skips. if so, it needs more tension and be sure every bolt is tight as shit...oh, and check the ps fluid.
Bone stock
SOLD
Old 01-05-2006, 08:11 PM
Turbo makes me emo!
I never did try the oil thing. But the squeeking persisted as normally. But then today I heard it squeeking around the 5k rpm - 6.5k rpm range. That pissd me off and I said fuck it, so the belts off and its back to that good ol non-power assisted steering. Its cold here so I won't need the A/C anyways.
Old 01-06-2006, 02:11 PM
Not sure if it's been changed or it's the same alt that came with the car. Im planning on changing that also.
2006 ECLIPSE GT - I believe it's the power steering belt, when i turn the wheel, it squeels..
Now i know the waterpump has nothing to do with shifter slipping out of 2nd gear, however, im wondering if the machinic messed something up in the process cause this never happened before. Now all of the sudden it's doing it
