Old 12-20-2005, 12:02 PM
NYC32798 NYC32798 is offline
Re: Re: Please Help!!!!!!
I took the car in to a technician and found the problem and got it fixed so I am just sharing it with everyone in case this happens to you. Unfortunately ignition switches in GM cars tend to burn up. The ignition switch was previously replaced I'm guessing because it burned up. Well the same thing happened only it didn't pop the fuse like it's supposed to and it didn't burn up the ignition switch which is usually what happens. When the new ignition switch was put in, they also replaced the harness that connects to the steering column. They used butt connectors to connect the harness. The wires fried up inside the butt connectors which caused a loose connection. So if anyone else has this problem, It would probably be either your fusable link going to the ignition switch (which I was told never does it's job) or a bad or fried ignition switch.
Old 12-20-2005, 08:43 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
How much did it cost ya?
