Old 12-18-2005, 12:12 AM
riccbhard riccbhard is offline
Also experience a quieter rattle at 1000-2000 RPMs. On this 98' it's the belt tensioner.
Old 12-18-2005, 12:22 AM
GirlBear's Avatar
GirlBear GirlBear is offline
Re: Re: Re: Re: Rattle at Low RPMs
Originally Posted by SultanGris
pointless, unless your dumb enought to park in tall grass, or touch them, heheh. bet you wont do it twice.
i rip them off also, but not till they start making noise.
I ripped mine off while changin the plugs. I also have same rattle. im thinkin either the heat sheild i diddnt take off on passengers side or H2o pump or cat. not sure yet.
http://jowulf.deviantart.com/
Old 12-19-2005, 11:01 PM
SultanGris SultanGris is offline
Re: Re: Re: Re: Re: Re: Re: Rattle at Low RPMs
Originally Posted by the87hyper
GOLLY your one smart cookie!! I think everyone knows that the spark plugs dont mount to the exhaust! Your missing the point i'm trying to make, and FYI they put the heat shield above the exhaust!! Imagine if there were no heat shield. Think of your gas line and brake lines!! You do know that your so called 1200 degree muffler can boil brake fluid? Well im going to assume that the engineers at GM have no f-king clue what there doing! till next time
well, dont know about yours, but my fuel lines are on the opposite side of the exhaust system, and im talking about the heat shields on the catalitic converter.
Old 12-19-2005, 11:55 PM
stoney1962 stoney1962 is offline
you may also might want to check your tourq converter bolts it happened to mine that way.
Old 12-20-2005, 07:23 AM
dirtnap300's Avatar
dirtnap300 dirtnap300 is offline
Originally Posted by cleanshavenrsx
the lines and wireing were set to be away from the exhaust... heat sheilds are pointless their metal the get hot and send off heat just as much........ maybe if they were made of something that dispersed heat more efficently...... but i do agree with the heatsheild surrounding the header but you were referring to the wrong heatsheild we remove the one under neath for the exhaust.... i have the look at the one for the headre closer... i think that one might make cooling the header with free flowing air more difficult thus being the heat sheild is sheilding heat and cooling
ALright everyone i think i have the answer for this.. My good friend has a 94 Bravada and he had something similar happen to him. We thought the sound was coming from the cover of the torque converter so we removed the cover but the problem/niose continued. After further listening to the "death rattle" i was alarmed that maybe (JUST MAYBE) his oil pump pickup may have fallen down inside the oil pan and when the engine revved it stopped since the crank and oil spray would knock it out of the way... but, that couldnt be it since there would be a loss in oil pressure... My second idea (and subsequently the right one) was that the flywheel flex plate was coming apart and that the noise was the sound of the cracks in the flywheel grinding as the thing wobbled at low RPM. When the motor was revved up, the noise went away as the centrifical force would take over and hold the flywheel out and the grinding would stop. But as soon as the engine returned to idle, the sound would come right back (and it was horrible it sounded like 2 peices of sheet steel grinding, end to end). After some checking we found a shop that would replace the flywheel for $325 and that fixed it... Heck the shop even put in a new front seal in the tranny for free since they had it down for the flywheel swap.. It was a tough call since you cant see in there but thankfully it was correct. The shop saved the flywheel and it had cracks connecting 3 of the 5 holes cut in it so it was just about to come apart violently. This may not be your problem... but maybe it is.... rattles can come from anywhere for any reason.
Old 12-20-2005, 05:38 PM
Emmitt101 Emmitt101 is offline
Had the same problem at idle and it turned out to be my cat.Let it go and it eventually stopped. Only because it clogged it. Ended up costing me $325. Change it now.
Old 12-20-2005, 07:29 PM
Blazerboy1287's Avatar
Blazerboy1287 Blazerboy1287 is offline
Send a message via AIM to Blazerboy1287 Send a message via MSN to Blazerboy1287
okay, here's the culprit... for anybody interested... it was where the cat connected to the headers... the clamp was rusted off, and the smaller header pipe was rattling loose in the larger cat pipe. i got a friend to weld it, so there is also no exhaust leak... problem solved... now i have to post a new thread because another new one showed up...
Black 1995 Blazer LT 4 Door 4x4 *SOLD*
@110000 miles
3-inch piping with a Flo-Pro V-Force Muffler
97 Eclipse GST (Burgundy) (powered mostly by Ebay)
123000 miles
Short throw Shifter
Ebay true 3-Inch Stainless Steel Catback
Ebay Intake w/ K&N filter
GSX dual piston upgrade
Powerslot Rotors
Akebono Ceramic pads
All synthetic fluids
"It is only after you have lost everything that you are free to do anything."
-Tyler Durden
Old 12-20-2005, 07:51 PM
aw man, the suspense is killing me, ive been waiting like 15 min for the new thread.
yes, thats how bored i really am.
Old 12-21-2005, 04:38 AM
dirtnap300's Avatar
Awwwww man, its over...... oh well i am glad he found the Death Rattle.
