#16
2 things I would look at. Frozen injectors (staying open too long at start since they're so cold, can you warm the truck in a garage overnight to see if it starts normally?)
Ignition module under the cap..(not the rotor but the actual ignition module)
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
#17
Re: Re: Re: Re: no one has fixed this????
Is your EGR operating properly? Ie good flow (no carbon chunks), good seal, etc?
2 Things I would do. 1st, run some seafoam through the system. (1/2 through the brake booster hose, 1/2 in the gas tank). Once that tank of gas is gone, then drop in some gasoline moisture removal with your next tank.
#23
I'd recommend taking out and cleaning every sensor attached to your intake plenum with paper towel + brake cleaner, as well as their gaskets. If the gaskets look wrinkled/cracked replace em. There's one in particular I'm thinking of (the one with the spring loaded plunger at the top of the plenum) but I can't recall its name. The TPS you can prolly not bother with. Then try changing your air filter.
spring loaded plunger.....doesnt sound familiar, but ill look.this might be crazy but.... i stuck a thing under my gas pedal. im almost convinced that its getting flooded, but there is nothing leaking inside. so just for the heck of it i stuck a quart of transmission fluid under the gas pedal. ive become so desperate that im trying EVERYTHING!
#26
Have you checked your fuel pressure regulator? If the pressure is to high it will overcome the poppit vavle in your injectors and cause flooding. In colder temps. gas will not evaporate as fast as warmer weather making it harder to start.
#27
mmmmm... Block heaters are a wonderous thing.
Up here in Canada, a car without a block heater is like a fish without water. Never had a problem parked for days in sub zero temps, blizzards, etc. COld wet, harsh, plug the block heater in, 1hr later, purrign like a kitten. ~XPC |
#28
Block heater
Oil pan heater Battery blanket Set it on a timer to come on 3 hours before you start it. |
#29
it could be your fuel regulator is bad
#30
i dont have a block heater.also my injector is new and the regulator is on the injector. this morning i tested the fuel pressure and it was fine, but heres what happened..... i turned the key on to see the fuel pressure, then i cranked it to see if it dropped or whatever, but it was fine. when i turn the key on the pump goes on for the 2 seconds, but....i left the key on for like 30 seconds, when i cranked it, it started right up. so at least maybe i found a way to get it started. but heres the other part...... when i shut the truck down, the fuel pump stayed on. i mean it stayed on like forever and wouldnt shut off, but once the car is warmed up, it shuts off when its supposed to. if i put the fuel gauge on the truck tonight, should it still be within spec tomorrow morning?
