Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 12-16-2005, 11:18 PM
TheGuyz TheGuyz is offline
Re: OK Need Serious Advice Major Engine Problems
Is the equation
>= 65 heat good engine not over heat with heat on,
< 65 engine overheats with heat on
car must be possesd as it is doing everything in reverse diagnostics.
Old 12-17-2005, 06:32 PM
alh27 alh27 is offline
Yeah thats what its doing. It's crazy i can't figure it out. It's the strangest thang I've ever heard of???
Old 12-30-2005, 10:01 PM
muff34 muff34 is offline
Re: Re: OK Need Serious Advice Major Engine Problems
Well are there any updates as to what the problem is?
Life Is A Highway ,Enjoy The Ride
Old 12-30-2005, 10:39 PM
nothing yet??? anybody else have any ideas??
Old 12-31-2005, 08:32 AM
send a private message to richtazz over in Grand Prix forum and run it by him. No disrespect to any people here but he is a Gm parts guy and seems very knowledgeable. bnaylor is also good but he`s into Gp`s. let us know how you make out Good Luck
Old 01-02-2006, 07:33 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Sounds like you have an air pocket in the cooling system. The heater core in your car is one of the highest points in the cooling system, so that is where the air settles when you shut off the car. When you turn on the heater, coolant pushes the air pocket into the engine, where it's getting staying in the cylinder head causing the engine to rapidly overheat. There should be a coolant bleeder valve on the t-stat housing that will help in bleeding the air out. A good repair manual will have the proceedure in it. Getting the air out is a pain in the a$$, but that's the problem you are having.
