Old 12-15-2005, 07:31 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Dome & Map Light, Door Lock Relay, Automatic Transmission Module, EEC Module (1.8L), EGI Module (1.9L), Ignition Light, Luggage Lamp, Radio (Memory) and Visor Lamps.
I thought there was an ignition relay but couldn't find one.
Nevada Tumbleweed
Old 12-15-2005, 04:50 PM
tmossa tmossa is offline
Re: Blower & Wiper Problem
I still cannot find any problems. Sounds like I can't leave the fuse out.
I'll keep searching.
Old 12-15-2005, 05:28 PM
It's got to be some wires smashed together somewhere unless they ran all that shit through the computer and it is messing up.
Some weekend you may have to just follow that cable from back to front until you find it. Pop out the grommets on each end of the cable between the hatch and body and see what it looks like in there.
This cable MAY be the one that runs under the rear seat cushion. Could be smashed there?
I think your jut going to have to follow the cable though.
Nevada Tumbleweed
Old 12-15-2005, 07:09 PM
I'v pulled the grommets and wires going to the hatch found nothing. I have even disconnected the computer and still the blower & wipers runs with key off. It also has fuses for power windows, power locks and sunroof and this car does not have these items???? I am loosing sleep over this thing!
Old 12-15-2005, 08:03 PM
Good New & Bad News! I finally found it! It's worse than I thought it would be. It seems that when the wires wear cut into at the back hatch opening (which wear repaired before) that it had melted down the wiring harness leading from the passenger side lower rear corner all the way across the back and at least to the back driver side seat. Thats as far as I'v looked so far, probably goes all the way to the fuse block. Good thing it had a fuse in there to protect it! Anyway looks like I'm going to the salvage yard for a harness. Thanks alot for the help! You gave me the places to look. Looks like case closed!
Old 12-16-2005, 07:27 AM
Good deal! Finally! This thread was getting pretty long. Sounds like you have your work cut out for you this weekend but at least you'll sleep good. Get-R-Done
Nevada Tumbleweed
