#16
Re: 95 Blazer 4x4
How strong should the vacum be? joe |
#17
Re: 95 Blazer 4x4
Cracked, pinched, blocked. How is the fitting at the other end? You could try blowing it out with compressed air.
Re: 95 Blazer 4x4
the parts guy told me it might be the check valve on the transfer case he sid they go bad all the time joe |
#19
Re: 95 Blazer 4x4
Just to clarify, you mean the actuator by the battery yes? I don't have my Haynes and searching other posts hasn't yielded information on vacuum strength, so hopefully someone else can post that.
And I think your mechanic is talking about the vac switch on the Tcase. Yes, these are prone to failure, as they get sticky fairly easily. They are an inexpensive part (~$15)
Re: Re: 95 Blazer 4x4
Joe |
#21
I just fixed the vac line on my 2000 last week. When I would push the 4hi button, I would hear the relay clicking and even the transfer case sounded like it was engaging the 4wd. The 4hi light would just keep flashing though and I'd have no 4wd. After a few weeks of randomly trying the 4hi I would still hear the relay but no sound from under the truck like it was engaging. When I checked the vac lines, the one that goes behind the distributor to the piece mounted on the firewall was off. One part of the line was still attached to the piece on the firewall. I figure it was cracked at first, that it why it sounded like it was trying to engage (prob just not enough vac to fully engage it). Than when the line totally split off, that it why I didn't hear it trying to engage anymore only the relay clicking. If yours is doing the same, I would definately check those vac lines. My last 2 blazers had that same vac line break in the same spot. And my first blazer had the sticking vac switch in the transfer case. It would usually stick in 4wd though. I used to have to pull the vac line off the actuator until I had the time to replace the vac switch. I would replace it usually every winter. Those are the only problems I've had with the 4wd on the 3 blazers I've owned.
Current Rides: 1971 Nova 2004 Tracker 2013 Sonic Past Rides: 2007 G5 1984 Firebird 2000 Jimmy 1994 Jimmy 1990 Tracker 1985 Jimmy |
#22
Re: 95 Blazer 4x4
Joe |
