Old 12-06-2005, 07:03 PM
srbianats srbianats is offline
You still have air pockets in the system. Your best bet is to get the system totally fushed and replace the stat and replace the radiator cap. Like others here preach, use stant cap only. Anything else sux and will eventually leak air back into the system or leak coolant out or both. Shop around for the coolant flush. Jiffy lube does a pretty decent job by me. I was the only one there while they were doing my Blazer. I got to ask plenty of questions and watch. They even recomended replacing the stat right away. Cost for the power flush was 100USD. If you haven't had this done in a long time or ever, then this is a good place to start troubleshooting.
98 Blazer LS 4x4 (STOCK)
.ǝɹǝɥʇ noʎ ʇǝb 11ıʍ pɐoɹ ʎuɐ 'buıob ǝɹɐ noʎ ǝɹǝɥʍ ʍouʞ ʇ,uop noʎ ɟı
Old 12-06-2005, 07:13 PM
Eslhockey92g's Avatar
Eslhockey92g Eslhockey92g is offline
Re: my temp won't hit 160
Yea i'll deff get that done once i get on brake from college, I bought the car at about 96,000 on it and now its got about 112,000 i already rebuilt the tranny, and i keep up on oil changes, just need a good coolant flush and i think i'll be doing good. Yea a mechanic i became buddies with told me to only get stant's as well Thanx for the advice
Old 12-06-2005, 08:15 PM
No problem. Good luck.
Old 12-07-2005, 12:11 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
You don't need another flush, replace the rad cap and make sure the overflow resevoir is not clogged at the bottom.
Also, swap in a new thermostat and you should be fine.
Make sure you install a 195f stat and nothing cooler.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-07-2005, 12:49 AM
BlazerLT, he said he did a radiator flush. Wouldn't it be a good idea to totaly flush the system out? His heater core could be getting patially clogged.
Old 12-07-2005, 08:14 AM
Chuky66 Chuky66 is offline
Just a tip. To do a good flush on a system, the stat should be removed and the flush ran through. You get better flow. I also like to loop my heater hoses so I'm not running crud from my engine into the heater core. Then flush through the core with a water hose both ways until you have nothung but clear water coming out.
Like I said, just another tip.
Chuck
Old 12-07-2005, 10:47 AM
BlazerLT's Avatar
AF -Advisor
Yes, my mistake, I thought he said full system flush.
Although we are getting a little off topic here, the rad cap should be replaced and a system flush performed along with a new thermostat.
