Old 06-04-2002, 09:45 AM
sweetcarz.com sweetcarz.com is offline
Banned
Send a message via AIM to sweetcarz.com
Originally posted by CXHatchback
ok, what about for 5th gens?
The 5th gens. require you to mod the cluster and do a bit of wiring.
Integra Blue Left side plug (13 pins)
1.blu tach signal
2.grn/org check engine indicator
3.yel/red oil pressure switch
4.Not Used
5.wht/blu change indicator
6.Not Used
7.yel/grn coolant temp.
8.blk ground
9.red/blue cruise (if you have it)
10.yel hot
11.Not Used
12.pink mantience (not used)
13.Not Used
Integra Right side blue Plug (16 pins)
1.grn/red e. brake signal
2.red/grn high beam
3.grn/yel right turn
4.grn/blue left turn
5.Not Used
6.blk/yel power
7.red/blk power
8.red power
9.blu/red abs (not used)
10.grn trunk swtich
11.org vechile speed sensor
12.Not Used
13.blu/white low fuel (cannot be used without Integra gas tank and sensor)
14.yel/wht fuel gague
15.grn/rd door switch (not used, can be with extra wiring)
16.rd/blu seat belt
Civic's left side grey plug (12 pins)
1.yel/wht fuel gague
2.yel/blue vechile speed sensor
4.grn/blu left turn
5.whit/blu charge
6.yel/red oil pressure switch
7.Not Used
8.blu tach signal
9.Not Used
10.blk/yel power
11.red/blk power
12.red power
Civic's right side grey plug (10 pin)
1.red/grn high beam indicator
2.grn/red e brake signal
3.Not Used
4.Not Used
5.grn/org check engine indicator
6.blk ground
8. yel hot
9.grn trunk switch
10.blu/wht seat belt
Note: You want a 94-97 cluster.
Old 02-09-2003, 10:51 AM
8psisi 8psisi is offline
thanks for the layout
but i need to know what wires hook up to each other.like left one on the integra hooks up to left five on the civic.there is to many wires that dont match up and i dont want to hook them up the wrong way
Old 02-09-2003, 03:31 PM
relientokay relientokay is offline
That looks awesome, i just might have to do that!!!!!!!
:flamer: Rice I like Fried Rice
:: 93 Honda Civic Si. D16z6 SOHC VTEC. Tanabe Super medalion exhaust. Injen Intake. DC Sports 4-2-1 header. 5% reer tint. JDM shiftboot. Sparco globe x shiftknob. :::: the only good rice is fried Rice:::: :flamer:rice
