Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 11-27-2005, 12:37 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: Re: Re: Vibration
Originally Posted by Elchicoloco86
engine braking from any higher speed is your best solution unless you have high-performance brakes and pads that you are absolutely positive can withstand the heat
and i think that having a 120lb girl in the trunk of your car directly above your rear suspension 24/7 could cause some wear and tear on the suspension part causing it to not hold up quite as well, thats just a theory though its not like you only riding in the car a max of 2-3 hours per day
if you get it fixed you'll have to get new tires too as well as an alignment
and if you have some extra money, i could use new tires too
engine braking is the worst idea. would you rather replace you rotors or your engine?
if you rear tires are getting bald on the inside more than any other part of the tire, and the car is lowered, you need a camber kit on the rear.
if your car vibrates while driving at speeds higher than 55mph while NOT braking, then its your tires.
if your car vibrates while you are braking(ie, the steering wheel shakes while braking), your rotors are warped
Old 11-27-2005, 02:20 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: Re: Re: Re: Vibration
[quote=eclipsed4utoo]engine braking is the worst idea. would you rather replace you rotors or your engine?]
I agree with that statement to a degree, and it would be your clutch, not your engine that would need replacing. I engine brake going down hills, and when im not in any hurry to stop. Otherwise I am very brake heavy, and my powerslot rotors show no sign of warping.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 11-27-2005, 06:02 PM
Re: Re: Re: Re: Re: Vibration
[quote=rodbls]
the synchros in the tranny will also be going pretty soon. i have never engine braked in my car. thats what i have brakes for. i also don't like having my engine constant revving at 4000rpms. i usually never get the rpms up that high.
Old 11-27-2005, 07:00 PM
rodbls's Avatar
Re: Re: Re: Re: Re: Re: Vibration
Different strokes for different folks...some people were taught to engine brake, some were not. Its a preference i guess more than anything. But it is a godsend in the snow.
Old 11-27-2005, 10:22 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: Vibration
yeah i'm not entirely for sure, but i do kno those rotors get super hot, and if you need to stop faster its likely not to happen, i prefer letting it in neutral and coasting if i have the time
Don't act like you don't love it.
503/2000
Old 11-27-2005, 11:59 PM
rodbls's Avatar
Yes, even stock brakes are capable of "glowing the rotors". Obviously on a stock pad compound this is a wost case scenario, and if you are in fact glowing your rotors, your brake pedal probably feels like mashed potatoes, and any notion of stopping is long gone. After you roll to a stop more than likely there will be smoke and possible fire roaring from your wheels as your brake pads will be on fire...and then there is the smell...that god awfull, buring carbon smell. If you have smelled it once it will never leave your mind. After the fire goes out, and your fluid stops boiling...you needs new pads and rotors...possibly new lines, and fluid. Street cars are not race cars, nor can we expect them to perform like them. Having good brakes is just as important, if not more, than good "boogy".
Old 11-28-2005, 12:02 AM
Sleepr awd's Avatar
Re: Vibration
yes indeed, good call, btw i think i answered your problem up above in case you didn't catch it
503/2000
Old 11-28-2005, 09:33 AM
cficare68's Avatar
cficare68 cficare68 is offline
Re: Vibration
I am hoping that the 3 Farad and the 1.2 Farad Caps I am ordering next pay will help out though
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
