Old 11-28-2005, 02:49 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Hello All
How did you clean the gasket surface?
What materials and chemicals did you use?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-28-2005, 07:59 AM
srbianats srbianats is offline
I cleaned it with a razor blade. Much easier that way. I used acetone to clean the surfaces. It evaporated quickly.
Old 11-28-2005, 11:04 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: Hello All
Awesome post!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 11-28-2005, 11:15 AM
BlazerLT's Avatar
AF -Advisor
Re: Hello All
Did you change the oil and coolant after you did this?
Old 11-28-2005, 06:23 PM
I changed the oil, not the coolant. It leaked almost all of it when it sprung the leak. Just finished the whole job. It started right up. Freaked me out after awhile because I saw smoke, then realized I spilled a tad bit of oil on the exhaust manifold and it was burning off. Got a squeak now. I think it's coming from the power steering pulley. I think I have to push it back just a tad bit more.
Thanks BlazerBoy.
Old 11-28-2005, 06:33 PM
Cailen Cailen is offline
Re: Hello All
Lol.. you should have seen the white smoke just billowing after i completed mine. I think I might need to replace my o2 sensors some time soon.... no troubles so far though.
Originally Posted by blazee
If you would pull your f ing head out of your f ing ass and read the f ing thread, you will see that I posted the most common f ing cause in f ing post # 4 and Swalt followed it up with more f ing details in f ing post # 8. From what we f ing posted you should be able to f ing realize that if you have two new f ing tires on the f ing front and two raggedy ass f ing tires on the f ing back... that is probably causing your f ing bang. Try not to be such a tool. Can you do that, Thank you. f head!
