Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 11-21-2005, 04:31 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Re: Re: best engine for my 91' crx dx
Originally Posted by AllmotorBB6
the difference is that that isnt as reliable as a completely stock motor. You're gonna be running low 13 sec 1/4 mile. It will basically pay itself off because you would have to maintain a high horsepower car alot more than a stock motor.
hmotorsonline has the complete changeover for 4000 dollars. You wont spend 9k. You might get close to 9k if you got the K20A (type R) which is 5600.
Right there you're at 9600....i personally would boost a bseries...there are plenty of boosted GSRs on Honda-tech that last a long time. i wouldnt discount them as unreliable.....reliability all depends on what you put into it....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-21-2005, 10:01 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
Hes not telling you to add the $4000 and the $5600 hes saying thats the difference in the K20a Type R
Old 11-21-2005, 10:55 PM
Schister66's Avatar
AF -Advisor
i think it was superbluecivicsi who had a good write up and he estimated the cost to be about 9k
Old 11-22-2005, 12:20 AM
Schister66's Avatar
AF -Advisor
i was wrong it was Brody P
Originally Posted by BrodyP
Hello and welcome to AF. If you are interested in an engine swap for a 01+ the best route would be a k20 swap. Below are the materials needed with prices. This is a lengthy process. The prices below are straight fromt he dealer you can also get some of these parts at a junk yard.
k20 intermediate shaft.................$220
Axles from 02+ si.........................$100 from junkyard
RSX Subframe............................$600(quoted from Acura) $150 from junkyard
Hasport Mounts............................................ .$400
Shifter Assembly.......................................... ...$100
Shifter Cables............................................ ....$300
02+ si radiator.......................................... ...$150 (TYC brand)
fans.............................................. .................$30 universal fan from autozone
02+ si upper radiator hose..................................$13
02+ si lower radiator hose...................................$11
RSX Throttle cable............................................. $40
RSX Fuel Line.............................................. ......$45
RSX Brake booster line........................................$45
RSX Purge Line.............................................. .....$40
02+ si ac line from compressor to condensor............$100
RSX Clutch Line From slave to master.....................$20 from junkyard
RSX high pressure power steering hose...................$240
RSX Power steering return line...............................$50
92-95 Civic Power steering resevoir with bracket.......$50
Optional Stuff:
Hondata........................................... ................about $900
Hasport/Hybrid Racing Engine Harness....................about $300**
(complete new harness)
So the grand total not including the motor on just the parts needed list for the swap comes out to roughly around $3800.
Just remember that this does not include the motor... i have seen complete motors that go for as low as $2000 for the SI to as much as $5000 or more for the JDM type R...
So now when you add everything that brings it up to roughly
$5900 or possibly lower to as much as $8900 or more.
Old 11-22-2005, 02:12 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Originally Posted by QUICK_EG_B16A
An OBD 0 B16A would be the easiest swap. probally the cheapest too.
you dont know anything. you are low on cash. you want a b series swap. that qoute above will make your life easier.
before you even think about all these motors, you need to be concerned with the dpfi to mpfi conversion.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
