Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 11-19-2005, 03:13 PM   #16
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: Cheap performance mods?
You're right, my worst experiences with platinum plug fouling were with Ford V8's also....I think they just tend to run too rich and sooty than some others, that's the common pattern with Ford carbs and Early TBI's, to wander to the rich side as they age.
I usually always stick to what the factory uses, I gave up long ago trying to see any tangible improvement from a spark plug change (other than worn out ones).
But if for some reason the OE plugs aren't readily available, I never hesitate to use NGK or Denso in their place. They make a really high quality plug.
I almost tried the Rapidfires in my Impala SS, but decided after replacing the coil, wires, distributor, and timing chain, (what a PITA, good thing it lasts 100,000 miles) that I didn't want to have to go back through it if I didn't like those plugs. I liked how it ran with the OE Delco plats, so I just stayed with what works.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 11-19-2005, 05:02 PM   #17
Manny_boy
Manny_boy's Avatar
Jeff...Dude, you are a lighthouse in the fog.
I wondered why I just could not get my lincoln to pass emissions, everything is fine, except hydrocarbons. Running too rich, even after a full tune-up.
I didn't know about the aging ford products going to the rich side.
COOL... I'm gonna yank that TBI off and do an overhaul next weekend.
thanks man... (x3)
...err, umm... sorry - didn't mean to hijack...
Behind a calm face is a disturbed mind controlled by music...
Junkyard Dog - Be careful...it bites!
Manny_boy is offline   Reply With Quote
Old 11-20-2005, 01:24 AM   #18
Bboy_Jon
dam ya i set my alarm to 6:45 and ya i didnt wake up until like 9 and i had to be somewhere at 9:30 so ya lol
didnt get to drill my holes yesterday (saturday) but now before work (as of now its sunday) since i have to work at 2
Bboy_Jon is offline   Reply With Quote
Old 11-20-2005, 01:43 PM   #19
Bboy_Jon
hey jefco i just tried to go and take the box out to drill
but ya its hard, i need to disconnect the metal thing in between the box and the tube
and i couldnt get it out do to the tube where the air sucks in, so i think i gotta take the top off so theres a lil more room, howd u get it out?
Old 11-20-2005, 03:40 PM   #20
jeffcoslacker
Yeah, take the top off so you can see what you are doing, and it all becomes apparent. Just take the lid screws out, loosen the clamp where the duct goes to the lid, and pull the lid out.
Then with the filter out, you can see how the bottom is held in. There might be a nut or bolt in the bottom, I can't remember.
That inlet tube is pretty flexible, you can bend it around a bit to work it loose.
...empty gun rack.
Old 11-20-2005, 09:30 PM   #21
Bboy_Jon
ya theres a bolt on the side, which i took off i just coultn fit it through with the lid still on and i didnt have time to take it off
Old 11-20-2005, 09:50 PM   #22
bigbadrat
Send a message via AIM to bigbadrat Send a message via MSN to bigbadrat Send a message via Yahoo to bigbadrat
Manny_boy what is the full site name.i copied and pasted but it doesnt work
bigbadrat is offline   Reply With Quote
Old 11-21-2005, 11:49 AM   #23
Manny_boy
Manny_boy's Avatar
Re: Re: Cheap performance mods?
www.fastfwdperformance.com
Old 11-21-2005, 09:59 PM   #24
bigbadrat
thanks man.have u bought the underdrive pulleys?if so did u notice the difference?
Old 11-22-2005, 11:35 AM   #25
zephram22
zephram22's Avatar
Send a message via AIM to zephram22 Send a message via Yahoo to zephram22
Originally Posted by Bboy_Jon
What are some cheap (as in hundred dollar ranges and stuff) performance mods?
I have a muffler (flowmaster) thats about it
What else can help the car get faster (i have a 97 lumina)
cold air intake?
what about drilling holes into the air filter box? (would the intake render this useless since theres no longer a box???)
new filter?
ehh what else is there?
I don't really know if a muffler would increase performance without having a new set of headers to go with it. Also, watch out that you don't change the backpressure too much or the engine won't run properly.
1963 Triumph TR3 12K
1995 Buick Century Special 178K
1999 Chevy Lumina LTZ 160K
2001 Suburu Forester 53K
2002 Oldsmobile Aurora 3.5 45K
2004 BMW Z8 3K
2005 Dodge Charger .5K
2006 Jaguar XJ12 1K
zephram22 is offline   Reply With Quote
Old 11-22-2005, 01:25 PM   #26
corning_d3
Send a message via Yahoo to corning_d3
My engine runs better than ever on less than 1 psi of backpressure.. I'm running 2.5 inch pipe front to back, hollowed out converter(resonates good) and a super 40 flowmaster. I'd say i gained around 10 horsepower.
corning_d3 is offline   Reply With Quote
Old 11-22-2005, 11:20 PM   #27
OffRoadSonoma
OffRoadSonoma's Avatar
Send a message via AIM to OffRoadSonoma Send a message via Yahoo to OffRoadSonoma
Backpressure is an old urban myth. It is not true that you need so much bad pressure. It will run just the same. The only difference is it will be louder than shit and then you can hear the way the engine is really running like if it is missing or stumbling.
OffRoadSonoma is offline   Reply With Quote
Old 11-23-2005, 12:27 AM   #28
Bboy_Jon
woot i drilled the holes its alot louder now especially around 4k rpms
Old 11-23-2005, 12:03 PM   #29
Bboy_Jon
ya i did a ghetto 0-60 test, and it fuckin hits 60 after around 12 secs! wtf
i was counting 1 1000, 2 1000, 3 1000, etc, i should probly use a timer
but ya wtf 0-40 its like 3-4 secs, then 40-60 takes like 10 lol
Old 01-16-2006, 02:42 AM   #30
GreySVO
Speaking of cheap mods for the 3.1 Lumina... I have a Fox Mustang, and you can adjust the timing, by advancing a few degrees after disconnecting the computer (then reconnect the computer)... also adjust the TPS. Is this possible with the Lumina?
GreySVO is offline   Reply With Quote
