Old 12-04-2005, 05:21 PM
iponnet iponnet is offline
ohh nope, didnt know I was supposed to do that..what does that do exactly?
thanks
Old 12-04-2005, 06:59 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: problem with 91 civic dx!
helps to seal better
Team Lonely Drivers
Old 12-05-2005, 01:13 PM
I havent put any coolant or oil in the system yet should I take the head off and put copper spray on the gasket or is it too late?
Old 12-05-2005, 03:39 PM
you dont need to put that copper spray on, it just helps alittle. nothing to worry about.
Team Lonely Drivers
Old 12-05-2005, 03:47 PM
let me clear this up for you. you use the copper spray because it will help seal any little imprefections you may have on the head or the block.
if for example you just had the head and block resurfaced then theres no need.
Team Lonely Drivers
Old 12-12-2005, 09:38 PM
alright, thanks for the replies, here is an update:
I put everything back on today went to start the engine and the engine cranks but does not run, I checked for spark and I get spark, so I am pretty sure I messed up the timing belt reinstallation but here lies the bigger problem, I didnt put any marks on the timing belt or the camshaft how should I align these now? or could this be a totally different problem? thanks in advance
Old 12-13-2005, 04:07 AM
the cam gear and the crank have marks on them for tdc
Team Lonely Drivers
Old 12-13-2005, 08:07 PM
I realigned them, with the tdc marks at the right place(maybe of by a tooth of camshaft?) still nothing,,,,I forgot to mention I adjusted the valves on the head, but dont think that would keep it from running? and I can hear the fuel pump turning on so I guess that rules that out.. I am gona get a compression set tomorrow and do a compression test maybe I did a royal messup when I put the head on or something I will update tomorrow
Old 12-14-2005, 10:02 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Check your grounds. The engine won't start if your grounds aren't all secured... especially, the valve cover gasket ground and the one connected at the thermostat housing. GL
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 12-14-2005, 12:29 PM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
after u noticed u may be off a tooth on the cam did u allign it back by that one tooth?
The Evil Sleeper
Old 12-14-2005, 03:18 PM
thats why like the instructions say, to get an adjustable cam gear because it will be off like 1/2 tooth and if you dont get it then it will be off
Team Lonely Drivers
Old 12-15-2005, 09:25 PM
yesss the car is running, thanks for all the replies I am such an idiot i had the distributer assymbly in 180degress wrong,,I know, I know,,,,,(what can I say its my first head gasket job) everything seems good accept I hear a ticking sound from the valve cover I am assuming the valves have to be adjusted since they resurfaced the head? and also like you said civickiller the cam has to be off by like 1/2 a tooth, but on mtchel on deand it doesnt say anything about getting adjustable cam gear!
