Old 11-13-2005, 08:29 AM
colinsdad colinsdad is offline
Re: Re: Questions from new Lumina owner
Originally Posted by tblake
oh, my god jeff, your post was not there when I typed mine, so very sorry, dont mean to step on toes here.
Thanks guys! I found the fuel filter, but cannot find the PCV...Oh well. Here's the wierd thing...I decarboned the engine, and the CEL went off for a little while, and then came back on AFTER the car warmed up....Any thoughts? All I get is 12 over and over again
Old 11-15-2005, 08:04 PM
Re: Re: Re: Questions from new Lumina owner
Originally Posted by jeffcoslacker
That's no problem, I forgot OBD I doesn't sense gas tank integrity anyway...
Well, the car failed inspection due to some rusted out tie rod ends, so the shop I purchased it from will run the codes while their at it.
Old 11-15-2005, 08:17 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Your PCV valve is located on the rear valve cover(closest to windshield).
Old 11-15-2005, 09:58 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Re: Re: Re: Questions from new Lumina owner
Tie rod ends rust locked? Dayum...it did do some sitting around, huh?
I had a customer in her 90's with a 1974 Chevy Chevelle her husband bought before he died....in 1977
She didn't have a driver's license. Had NEVER had one. The car had 16,800 original. The only time it EVER got used was when her son and family came to town for holidays. That's the only reason she kept it, so they didn't have to rent a car while there. The rest of the year it sat there in her garage.
I'd have to go get it with the tow truck for it's yearly oil change and inspection, and there'd always be something wrong with it that you'd never see on any car.
Like the brake proportioning valve siezing. One time it wouldn't stay running. Had a huge birds nest in the muffler, choked it up. Mice ate the harness for the headlights once. Tires got permanently flat spotted from sitting in one position with low air for 12 months. Couldn't run the lumps outta them (I tried). Fuel pump diaphragm would split and pump fuel into the crankcase about every other year. U joints got so stiff and dry, they started sqeaking like bedsprings when it was moving. Went to slow down while pulling it around the building to bring it inside, and the wheel cylinders in the rear brakes blew out Whee! No brakes!
Oh, and a new battery, every year....
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 11-18-2005, 03:30 PM
Here's what happened....I brought the car in for inspection, only to get a Safety failure (i.e. front tie rod and bushings were shot) and then have the e-brake lock up AFTER the test was performed.
The shop I bought it from replaced the following:
1) Vacuum hoses-to MAP and EGR (code is gone)
2) new rear brakes and rotors
3) new front suspension parts
cost of parts: 225$
cost to me:0$$!!!!
They have a guarantee that the car will pass inspection, or it will be repaired to pass inspection for free!!
Old 11-19-2005, 03:05 PM
cost of parts: 225$
cost to me:0$$!!!!
OK....now I have a code 32....WTF??????
Old 11-20-2005, 09:29 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
I believe code 32 has to do with your EGR system.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-22-2005, 10:37 AM
zephram22's Avatar
zephram22 zephram22 is offline
Send a message via AIM to zephram22 Send a message via Yahoo to zephram22
I tried searching the Forum with that function, and had no luck...
I just purchased a 1993 Lumina with a 3.1L...literally, a little old lady owned it and it was sold to me by her Family when she went into the nursing home. The engine and interior are VERY clean, but it's obvious VERY little routine maintenance was done under the hood.
I have a CEL that lit right after I bought it, and I figured, I would check the EGR, PCV valve and clean out the Intake manifold by finding a vacuum line to shoot some Intake cleaner in to "decarbon" the engine. My only problem is:
1) the car came with NO owners manual
2) I have a scematic that evidently a hyperactive monkey wrote on the radiator support that doesn't really SHOW where everything is. Also, anyway to "adjust" the MAP? This is the first car I've owned with a MAP rather than a MAF sensor...
Anyone have any pictures as to where the EGR and PCV are located, and are there "typical" things (ie. coil pack) that fail to cuase a CEL? I'm assuming Autozone can read it for free, but the closest one is a 40 minute drive...any help would be great!!
I would invest in a haynes manual. They are only 15 bucks and will be a life saver.
1963 Triumph TR3 12K
1995 Buick Century Special 178K
1999 Chevy Lumina LTZ 160K
2001 Suburu Forester 53K
2002 Oldsmobile Aurora 3.5 45K
2004 BMW Z8 3K
2005 Dodge Charger .5K
2006 Jaguar XJ12 1K
