#16
Re: Crankshaft Postition Sensor replacement procedure?
The oil pressure sending unit, if bad, will cause the car to stall and not trip a CEL or code. There is a safety feature built in that will kill power to the fuel pump and ignition module if the oil pressure reading drops below 4psi at idle.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
#17
Same trouble for me and my '95. 6mm bolts were too small I ended up geting 1/4 bolts with a 28:1 thread. Worked fine. Probably messed up the threads in the Harmonic Balancer but I'll only need to remove it one more time anyway
95 Bonneville 3800 Non-Turbo 200K+ Miles Purchased 2004 for $1K Not one moments trouble with it until 8/07 |
#18
i'm having the same issues with my 1995 bonneville driving down the road it will suddenly drop voltage and the buzzer (the same one as when the fuel is low) goes off and the car dies for a second and then catches itself and keeps going and the CEl comes on. but if it's idling it ussually stalls out. i tried replacing the IAC and TPS sensors and no change i checked all the gronds also.
