Old 11-04-2005, 07:23 PM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Re: well....
Originally Posted by KA24DEPowered
Its an S13...not an S14. I wish the LMGT4s came in 17
They do, you just have to order them from japan
18x8.5" +25 Fronts
18x9.5" +12 Rears
Sound good?
The fronts will fit with a Roll. The Rear will need a 30mm pull to fit but yeah it would fit.
Personally Id do 17x9 +10 Front and 18x9.5 Rear if I had money for better wheels. Right now Im running 17x9 +20 all the way around (S14 Front Lower Control Arms) and Im at about 2.7~5 front camber and stock poor boy camber in the rear and all I needed was a fender roll.
What do you mean low enough?Just to get rid of tire gap? My friend runs 18s and its fine on an S13.?
Low as the frame rail or fender arch low... I could tuck 18s all the way around and my car would still be a mile off the ground. As my car sits right now my frame rail and oil pan are about 4in off the ground.
What process do people do to tub the front wheel wells? Custom metal work or what?
Depends, I did a write up in the tech section on what you need to be low with decently sized wheels. However once you get into the wider 18in sizes on S13s you'll prolly need to tub the front wells infront of the strut tower to get to full lock
Old 11-04-2005, 11:05 PM
KA24DEPowered KA24DEPowered is offline
Banned
Send a message via AIM to KA24DEPowered
Thanks
That helped thanks...Whats the biggest you can get up front without tubbing? On a 17" rim?
Old 11-05-2005, 03:02 AM
R.W.240's Avatar
Banned
Re: Who the hell sells nismo rims??
You shouldnt have to tub for any sized 17s on the front.
On MOST Coilovers (some Brands like D2 an Zeal have smaller lower brackets for less scrub radius.)
17x9 +20 235/40
17x9.5 +12 235/40
Those are pretty much the minimum and maximum for the front... 9.5 may be infrigning on overfender territory depending on your taste.
Other than that I know 18x9 +15 is a decent fit with 3 degrees of camber and some hammering.
Old 11-05-2005, 02:56 PM
Banned
Ok...
Ok what about the rears?
17x10 +12 Sound good I plan on running 275/40 on the rear.
EDIT: Wont 235 on a 9 or 9.5" rim have a decent stretch?
Old 11-05-2005, 04:59 PM
R.W.240's Avatar
Banned
Ehhh... its not that big of a stretch. 255 is perfect square.
17x10 +12... I smell FN01Rs... 275 should be perfectly square though.
