Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 08-02-2001, 05:49 PM
P10DET's Avatar
P10DET P10DET is offline
Originally posted by AznVirus
where the hell do you guys get the tools to do it? well i understand Luke would have one cause hes a shop owner, but P10DET you have a motor lifter (rack)?
I have an engine hoist on semi-permanent loan from one of the Houston SERCA folks. He bought it to swap and engine in another car of his and never used it. I've used it 3x and about to use it again in a month or two.
None the less, hoists are not that expensive. They can be had for less than $200. I've sure gotten my money out of this one. :silly2:
As for other tools, I have a compressor and air tools, but I hardly used them at all on the swap. And my first two swaps were done strictly with hand tools.
I don't have a car lift and don't need one. I just use a 3 ton floor jack and a pair of jack stands to get the front of the car up high enough to slid the engine underneath. It's actually easier than it sounds and sure beats trying to do it from the top.
Back to tools, I've been wrenching on my own cars since before many of you were alive. I bought my first socket set 22 years ago and was wrenching on my cars before that using my father's tools. Twenty-two years is a long time to be collecting tools. Also, I used to race karts, and there is no quicker way to accumulate tools than to go racing.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 08-02-2001, 06:16 PM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
lifting it up w/ jack stands???
mine only go up 14"
lol.. how'd you fit the engine in underneath...
Old 08-02-2001, 07:36 PM
P10DET's Avatar
mine only go up 14"
I'm a stud.
Actually, I lift the car in two steps. first I raise the car enough to get the jack well back on the cross-member. Then I crank the jack up as high as I can and place the stands where the control arms attach (at the back of the control arms). It usually gives me about an inch of clearance.
George Roffe
Houston, Texas USA
00 328i
Old 08-03-2001, 03:45 AM
G22DET's Avatar
G22DET G22DET is offline
Send a message via ICQ to G22DET Send a message via AIM to G22DET
or, if you guys check with your local pepboys, they actually rent out hoists (or cherry pickers), engine stands and really cool hydrolic jackstands that lifts the car about 25" off the ground or so. it's pretty cool!
Luke C.
GDA Power!
Old 08-03-2001, 09:08 PM
PrimeraGT PrimeraGT is offline
Send a message via AIM to PrimeraGT
okay, so back to the original question.. other than the price.. hotshot vs FMAX? pros / cons
-often imitated, never duplicated..
Old 08-04-2001, 09:45 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
They look to be about same...I'd say the hotshot is a more stealthy install but the turbo that comes with the f-max will support more hp.
Old 08-04-2001, 07:16 PM
P11GT's Avatar
P11GT P11GT is offline
Send a message via AIM to P11GT Send a message via Yahoo to P11GT
turbo kits
After speaking to Hotshot, they told me that their kit was designed to fit and run on standard internals and gearbox, clutch, etc, whereas the FMax kit, as you say, can produce more HP, will inevitabaly require more mods to run reliably. I still dunno, but to me, the Hotshot sounds a bit better, due to the fact that its cheaper, and i dont really wanna go beyond 200BHP if i have to start uprating everything.
Any opinions on this are most welcome and may sway my decision.
Old 08-04-2001, 07:22 PM
G-Forces's Avatar
Banned
OK maybe a little confusion here. The F-max stage I is a little more expensive than the Hotshot. Both will run with stock internals, both will need upgraded clutches. Both will eventually need upgraded/new motormounts depending on how rough you treat you new power. If you're going to upgrade or want more power in the future get the F-max if you think you'll be happy with what the hotshot gives you now, get that.
Old 08-05-2001, 11:25 AM
Blackfoot Blackfoot is offline
do you have a website or phone number for hotshot?
Old 08-05-2001, 11:31 AM
G20er G20er is offline
Here is Hotshot's website addy http://64.38.203.52/temp/hotshot/products.asp
L8R
G20er
Old 08-05-2001, 12:04 PM
thanks g20er. they list applications for nissan, but no g20's. offhand, do you know if their kit will apply for a '99 g20?
Old 08-05-2001, 12:13 PM
Read this http://www.automotiveforums.com/vbulletin/t3926.html
L8R
G20er
Does anyone here have a Hotshots Turbo? Domiken Engine 3 04-14-2002 09:11 PM
hotshot turbo questions jcl603 Engine 0 01-11-2002 06:43 PM
Hotshot Turbo? xpo Engine 59 11-02-2001 04:18 PM
Hotshot Turbo Kit Caribbean NISMO Engine 0 08-25-2001 08:17 AM
HotShot turbo kit G20er Engine 4 07-09-2001 06:19 AM
