Old 10-24-2005, 11:31 AM
Morley Morley is offline
A shop is going to hit you for about $500 for a pump R & R. While in there replace the strainer "sock", pulsator and the seal for the pump access panel.
Old 10-24-2005, 01:24 PM
SG007's Avatar
SG007 SG007 is offline
Send a message via AIM to SG007
Re: possible fuel pump problem
ok. yeah screw paying all that for maybe $100 worth of parts. thanks.
-2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*-
Old 10-24-2005, 02:54 PM
AFI 05 AFI 05 is offline
Send a message via AIM to AFI 05
Re: Re: possible fuel pump problem
Originally Posted by SG007
AFI, how much did it run you? I have to bring it to a shop because I can't do it myself. Even the redneck way (cutting through the floor pan) I can't do. I can't even get it running to drive it the half mile to my shop.....UGH. I'm probably going to have to tow it.
uhh the fuel pump cost me around $75 at auto zone and you HAVE to buy the strainer as well that goes attached to the pump or else it will void the warranty they give you. Well, i never even asked for it but the guy gave it to me anyway so i bought it.. the strainer is like 4 bucks and I did the work myself (which was a real task). You have to remove one of the crossmembers, the muffler and tailpipes, heat guards and then you have to struggle to get the tank out cause the pipe that goes from where you pump the gas is attached to it so you have to manuever it around. I suggest if your gonna do it, take out the gas.. cause your gonna need to mess around with the tank in order to get it out.
1990 IROC-Z 5.7 TPI (1 out of 4,213 IROC's made in 1990) Only mod is magnaflow 3" cat back and K&N filters... im broke.
Old 10-24-2005, 02:55 PM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
75$? I paid 600$ for a 4th gen brand new from GM... but I was in a pickle and had to be done... they go for about 400 if you find outlets etc
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
Old 10-24-2005, 03:05 PM
SG007's Avatar
whats the best way to get my gas out? does the hose idea work? i filled the tank earlier that day, before it died. i have GREAT timing....lol
Old 10-24-2005, 05:12 PM
Matt365's Avatar
Matt365 Matt365 is offline
Send a message via AIM to Matt365
siphon it out....
Old 10-24-2005, 05:18 PM
Yeah suck on a hose, get a big barrel, when you see the gas let it come out and try not to get it in your mouth, it sucks
Be Warned....
XENO...
Xtreme
Emotional
Neurotic
Ominous
Old 10-25-2005, 11:20 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Maybe I missed it in the middle of all the kidding around, but ahve we verfied the pump is indeed 'dead'?
Old 10-25-2005, 04:46 PM
SG007's Avatar
well, I can't hear anything prime when I turn the key. i'm going to replace the relay first, before i start tearing the back end apart, but...i can't see naything that could be the culprit besides the fuel pump.
Old 10-26-2005, 08:48 AM
wrightz28's Avatar
yeah, definately keep it simple before you start going after the tank itself. usually the pumps will just die without any warning aside from being a little bit on the noisier side prior to their demise.
I'd definately do some checking around of the little things first like the relay, fuses and oil pressure switch connection. My pump dosen't prime that loud either, when I wasn't certain, I had to take the filler cap off and listen through there.
Old 10-26-2005, 10:49 AM
SG007's Avatar
Will it prime even if I don't actually turn the car ON? I guess I should have someone else do and stick my ear in there. I just went last night to Advance and they didn't have the relay in stock, so then I had to go to Autozone WHICH I HATE, and they didn't even have the part in their COMPUTER! This whole electric-in-tank setup really sucks.
Old 10-26-2005, 11:04 AM
yes, when you move the key up to "on" but your not really cranking up the engine, you should hear the pump. it goes for like two or three seconds.. then it goes quiet until you actually crank it up
Old 10-26-2005, 11:47 AM
SG007's Avatar
I reeeeeeeally hope it's the freaking relay.
Old 10-27-2005, 03:22 PM
I reeeeeeeally hope its your freakin relay too.. good luck
Old 10-27-2005, 04:21 PM
Matt365's Avatar
Originally Posted by Xenostalgia
Yeah suck on a hose, let it come out and try not to get it in your mouth, it sucks
ummm
that kinda input was not needed her xeno.. Im sure if sg needed that kinda advice she woulda asked someone besides you.
