| Latest | 0 Rplys |
| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
Show Printable Version | Email this Page |
#16 | |
lets say I have a 7.0L V10 that I want 800 hp from it, so I twin turbo it. Now is there a way to get the turbo hitting full boost or just under it at 2000-3000 rpm and continue the boost all the way upto the redline(about 8,500 rpm)???
#17 | |
That thing got a Hemi?
Re: Does a turbo restrict your engine's rev??
yes, it can be done. mainly because with such a big engine there's plenty of exhaust flowing out to get the turbos to spool up fast. you might need some proper boost control at high revs to keep it all in good order.
Seatbelts Saved My Life
#18 | |
wow thats awesome. If the 2 turbos spool at 2,000 rpm and give full boost until redline thats hardly any lag at all. some cars idle at like 800 rpm. Also would this make the powerband wider??
#19 | |
yup, it should do with the right tuning. the lag comes from big turbos an smaller engine, but the bigger the turbo the bigger the lag (compare turbo size to exhaust flow to get that)
#20 | |
so basically
bigger engine= less lag with bigger turbos smaller engine= more lag with bigger turbos also wats the diffrence between a flat and wide powerband??
#21 | |
240SX Guy
WTF is the point of full boost at 2000rpm on an engine designed to spin 7000rpm+ anyways?
-Cory 1992 Nissan 240sx KA24DE-Turbo: The Showcar Stock internals. Daily driven. 12.6@122mph 496whp/436wtq at 25psi |
#22 | |
so theres no lag lol
#23 | ||
flat isnt to do with the powerband, the powerband is the range in revs at which point the engine is at its peak power: e.g. you have an engine making a maximum power of 400bhp a wide powerband means there is a big range at which the engine is making maximum/almost maximum power within the two point on that given range. so, it makes ~400bhp between 6500 to 7500rpm, then the maximum powerband is 1000rpm (6500-7500=1000) but this varies between engines and setups. the "flat" refers to the power/torque curve (for definitions of bhp an torque search for the thread on it) a flat curve means its not very steep, or has a shallow gradient. a tall curve means its steep, or has a tall gradient. hope this is right an makes sense.
#24 | ||
Banned
i know what a cyntrifical superchargers is...i was talking about boost drop. |
#25 | |
you mean the boost drop where halving the rpm cuts the boost down to 1/4 ? i cant see that as being true, i mean if its spinning twice as fast it can draw in twice as much air. so how would the boost drop to 1/4 of the amount ?
i think that if you double the rpm, you double the boost. if you halve the rpm, you halve the boost. so its in a constant ratio.
#26 | |
Banned
basic mechanics says boost stays constant as airflow dobles when RPM doubles causing engine air consumption to double.
however im not a cyntrifical compressor expert so depending on the impellers compression map it could be true though i doubt it. |
#27 | ||
240SX Guy
Second, you don't honestly think a powerband can last for 5k on an average street car do you? Factory cars make full boost by 2k. And they suck for top end power.
#28 | |
240SX Guy
That rule only applies to positive displacement compressors.
On centrifugal compressors, boost increases as the square of the speed of the compressor wheel. Flow can increase phenominally without a large increase in wheel speed. AKA dynamic compressor.
#29 | |
![]() Join Date: Mar 2002
I'm pretty sure a turbo sized too small can cause flow restriction (backpressure) at high speeds, causing a drop in redline.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable. |
#30 | |
oh, yeah. too small a turbo will create back pressure an wont do the engine any favours. it wont just cause a drop in the redline, but without anywhere to go (if the wastegate isnt up to the job) then you could blow something up, either having exhaust forced back into the engine, or blowing exhaust manifold seals/gaskets...
..i dunno. i haven't tried over-boosting recently.
