Old 10-03-2005, 07:17 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: I'm done with AWD!
TOO lean kills a motor, more lean than rich makes power, more rich than lean you start losing power.
95 Talon TSI AWD
97 Eclipse GST
Old 10-04-2005, 09:52 AM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
Hey guys, I slipped into my college account and borrowed $200 bucks. I now officially own an SAFC2! But anyway, I bought it used without installation instructions, so if anyone has a vfaq on that, it would be great.
Also, Is there any way to learn to tune this on my own? I've talked to a few people who say that I don't have a choice but to take it to slowboy 'cause I won't be able to tune it properly? Is this true? I do have access to a logger if that changes anything. One last question... Is the knock sensor that comes on the SAFC2 reliable?
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 10-04-2005, 09:30 PM
kjewer1 kjewer1 is offline
AF - Advisor
You can tune it on your own with a logger. THere was a good write up by Kyle T over at www.racingknowledge.org in the DSM sction. The AFCs knock feature does not work with a DSM knock sensor. You have a 1g so, the pocketlogger or TMO logger etc will read the stock knock sensor, and that is what I would do. I used the TMO logger on the 91 and liked it. Good display (way better than usinga palm device, and you can get an acceptable laptop for less than 50 bucks), and easy to use. The advantage of taking it to slowboy is that they can use thier WBO2 sensor to get AFR right on. Still no good way to unfuck the half assed stock 1g high load timing map.
The injectors put you about 18% too rich, but remember also that the 2G mas reads about 20% lower at the same airflow Almost cancels each other out. But like I said above, it is not a linear adjutsment for the 2g MAS. DSMlink has preprogrammed compensation for a 2g MAS FYI.
Running lean can cause damage, but makes more power. Running rich reduces power but can add some safety margin. Running VERY rich can damage the motor if the excess fuel washes the oil off the cylinder wall (bore wash).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-04-2005, 09:40 PM
UnderEstimate Me's Avatar
UnderEstimate Me UnderEstimate Me is offline
Stop trying to convince him that awd is better. (Lets trade straight up right now my fwd for ur crappy awd )
2005 Neon
Stage 1 PCM l K&N CAI l Mopar rice plate l 3'' TBE l Spring mod l PB shift knob l Mopar strut bars F&R l ACR sways l Tokico Shocks/ Tein Springs l Ricey wing removal l JMB Catch Can l QW FMIC l Autometer WB l Diablosport Predator
Old 10-07-2005, 01:09 PM
Re: Re: I'm done with AWD!
Would I actually be better off to put the 1g mas back on then? Also, I noticed that the write up on how to use the AFC says "Don't even begin to do anything unless you have an FPR for the Walbro 255." Which I don't... So does that mean I have to spend more money now?
MOD LIST:
Old 10-07-2005, 01:27 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
you can do anything you want. It's highly recomended you do infact buy an Aermotive or other reliable FPR. Idle, cruse, suffers a bit without one.
DSM geek
Old 10-07-2005, 03:15 PM
Are you going to go with a bigger turbo down the line? If not then a 190 would have been fine and you dont need a fpr for it.
2005 Neon
