Old 11-08-2005, 07:19 AM
psycho_njm psycho_njm is offline
Send a message via MSN to psycho_njm
Re: Re: Mass Airflow Sensor
Originally Posted by shorod
A MAP sensor is a Manifold Absolute Pressure sensor. It connects to manifold vacuum and contains a pressure switch inside. The Mass Air Flow sensor uses a heated wire and a reference wire and monitors the amount of current required to keep the heated wire at a set temperature. The two sensors are not the same and are not interchangeable. If the parts store told you they are the same, they are in error.
-Rod
Irregardless of "exactly" what it is.... The Mass Air Flow Sensor "assembly" was the problem.
