#16
Lumina sputters and Dies when hot
I have the same problem. Did you find the problem? We have checked and replaced the following
plugs/wires/fuel filter, air filter, throttal positioning sensor, crank sensor, and computer module. After every attempt problem reappeared when auto hot. I found what I "think" is a vaccumn hose. The shape of it looks like it goes into the "throttal body" somewhere but I haven't found the connection yet. |
#17
Re: Lumina Dies randomly... weird problem
replace your Ignition control module, that is what i am told is wrong with mine. they are about $152 new at autozone (bay area C) and like a $15 gasket, if you have replaced the comp and that has not done it replace the ICM. mine is being done on monday by my brother at his GMC/pontiac dealership he works at. we used a tech1 scan tool and it wasnt the comp. and the ICM was acting odd... and i was told by a couple mechanics that usually the ICM is going bad but people think its the computer.
#18
Re: Re: Lumina Dies randomly... weird problem
i was crusing on the inter state nd going about 45 mph then opened it up to aroud 85 then was decellerating again then the car fell flat on its face and won't idle at all and i could only go about ten mph i found one bad injector but replaced then all ran good for about a month now having similar problems again sounds like yours \ mine seems worse when is warned up it also idles alittle rough not nice and smooth like when injectors where first replaced maybe have the injectors checked or cleaned |
#19
every oil change i use injector cleaner, and i checked them they all ran fine with the right voltage. yours sounds much diffrent then mine, when my car did its little thing on the freeway it just dropped a lot of rpms like there was no spark so no engine and then jumped right back up. we have got it down to being the ICM and i am having it replaced today or tomorrow whenever i get the time and my car back from my bro.
#20
Its Alive!!!!
Okay my car is now fixed and working perfectly.
I replaced the ICM (Ignition Control Module) It cost me $99 at Autozone. Lifetime warranty and made by wells. Car runs like a champ. no more problems i hope and more work is picking up with my 2nd job now and im going to start doing my interior work on her.i started working on her this morning at 7:00 in the freezing cold with no jacket.. my head was steaming hahaha. i finished at 11:00 My Lumina ate my 7/32 Socket and extension 1 time, i recovered it after about 20 mins.... and then it ate my 7/32 socket... i couldnt get that one out, i had another so it didnt matter at the time. getting the coils and stuff back in place was a pain in the butt. but i found if u shove it all the way up left, it kind of sits in place and just screw in the far right coil and life is easier. This is an experience i would rather not do again, although my car was dead cold... was very stressful at times. i still have yet to find that missing socket in my car and im driving it! hahahaha. it will eventually fall out. I know it went behind the starter and down into the cradle somewhere, or i think it did. im not worried. my car has eaten my tools before. once it was a Socket wrench that took some time and work to get back.. now i promised her if she worked good i would clean her time to wash and 2x coat wax my baby.She really is the devil in a red dress : /
#21
Re: Its Alive!!!!
]), but is the ICM the same as the ignition coil? Instead of the standard "distributor" which is fed by a seperate coil, this car has a harness that plugs directly in there (I'm assuming the coil module is inside?).Your symptoms/solutions also sound similar to my reply on this thread: (http://www.automotiveforums.com/vbul...d.php?t=268400) |
#22
Re: Re: Its Alive!!!!
Okay, your best bet. if you have a day off, and another ride to autozone go ahead and pull your Ignition control Module, the coils sit on top of it. take it to autozone and they can test it. just make sure you have your car nice and cold when you do this. the coils are in the front of the car above the front exhaust manifold. you will have to take the bolts out kinda blindly but it can be done. When putting the ICM back in place, shove it all the way up left, and it will kind of find its little groove to sit in. you will feel it once you hit it. then slap on teh far right coil, bottom bolt first and start screwing them all in. |
#23
Re: Re: Re: Its Alive!!!!
HOWEVER, the idle would still be very jerky.. with RPM's flutuating up and down. I tried giving it some gas... the RPM's when then drop the instant I tap it, then climb up...and immediately drop to a point of stalling (it stalled a few times). I tried resetting the ECU to let the ECU re-learn... no luck. This time I opened up the air box, removed the MAF, and cleaned the TB and maf w/ intake/carb cleaner and everything else... and a lot of gunk came out. I tried starting the motor again...same results... I let the car idle to burn off all the junk. It idles for about 5min or so. I then tried giving it gas again after... and the second I even tap the gas, engine splutters then stalls. Keep in mind, the whole time the engine has been running super rich... as if the combustion chamber has been flooded. I did some more searches, and found these other possible causes: EGR IAT (I believe this car has one?) ECT (coolant temp sensor) Does anybody have a diagram of these components (location, procedures, etc)...or can suggest anything else? Thanks again -Jeff
AudiGeeks.com: Where Knowledge = Horsepower |
#24
Re: Re: Re: Re: Its Alive!!!!
i had similar problems with my 91 w/3.1 i was running extremely rich after pounding my head agianst a wall for a couple of days checking different things i finally took off the upper intake manifold and checked the injectors with an ohm meter i found one realy bad one and a few others were on the low side of being good the realy bad one masured only 4 ohms others were from 11.6 to 12.5 they all should be around 12 ohms i replaced them all with reconditioned ones since i couldn't aford new and car runs well now idles drive ect. maybe look there |
#25
Re: Re: Re: Re: Re: Its Alive!!!!
#26
Re: Re: Re: Re: Re: Re: Its Alive!!!!
a while ago so i new it was good the egr will cause a code if it is bad (one of its componets not working or if it is stuck) if an egr is stuck open will cause a lean fuel mix and through a code if you have the time check your injectors i would deffinitly check them before buying new ones new one are like $65 each (at autozone) i found reconditioned at injectors4u.com for $16 each but i am not an expert just sounds similar to my problem iac will only affect idle |
#27
Re: Re: Re: Re: Re: Re: Re: Its Alive!!!!
Forgive my ignorance, but where exactly is the IAC located at? Any diagrams/pics would be appreciated. I figured the car has 115k, and I dont think the IAC was ever cleaned or replaced. Also..any thoughts about replacing the fuel filter that could probably be another remedy? -Jeff
#28
Re: Re: Re: Re: Re: Re: Re: Re: Its Alive!!!!
iac is in the throtle body it is black with two torx screws holding it in place it has like 4 or 5 wires going to it it is sort of round with a oval flange that the bolt go thru i think this too would give you a code but it is worth looking at is your check engine light on? the car runs fine off idle? if your check engine light is on autozone can read your codes for free and they may even help you locate the sensor or the have these key things you can buy for like a dollar or two that you can plug into the aldl connector to get the codes your self and i would buy a haynes manual ($15-$20) it tells you and shows you a pretty good descripition of the idle air controler |
#29
Re: Re: Re: Re: Re: Re: Re: Re: Re: Its Alive!!!!
A faulty IAC or EGR would have thrown a code i suposse? I've had a few people (including yourself now) telling me it's the injectors, and I will have them tested tonight and let you guys know the results. If it IS the injectors, it could possibly be #6 (most people are complaining about that one), and that's the same cylinder giving me the missfires. Thanks again Jeff
#30
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Its Alive!!!!
just make sure you check them before you buy them you also may want to get a noid light it is a test light that plugs into the injectors electrical connector to check for a pulse from the computer you may have to do this with the manifold off so i would disable your ignition by pulling the dis fuse to prevent the car from starting plug in the noid light and crank the engine you may need an assitant to look at the light or crank the engine also look at your wiring for the injectors make sure none of them are worn thru and shorting out this could cause your injectors to not work but it if there was a short it would or should blow the injector fuse good luck |
