Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 09-25-2005, 10:17 PM
Black97GST Black97GST is offline
Re: Crankwalk question
there are MANY people that would disagree with you Pinkslip, but thats just your opinion and you are entitled to it, however its not a PROOVEN fact that ALL 4g63 engines WILL get crankwalk. so that is just your assumption and nothin else. just to clear everything up.
  #17
Old 09-26-2005, 12:49 AM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Who says crankwalk is bad?!?!?! I just installed one in my car and damn it pulls like a mofo! It's the latest thing...
Okay dude seriously you should only 2% be worrying about something like that when looking for a Mitsu. I'll admit I was freeked out at one point in time too but just make sure you have just a little extra cash on the side incase something happens up to that degree even though it 95% won't.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
  #18
Old 09-26-2005, 08:04 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Re: Crankwalk question
Originally Posted by pinkslipRT
yes josh as u say it will happen, and i also stated above why and which 4g63, the 7 bolt 4g63 gets this problem and again its not if its when......(for this particular engine,7 bolt)
You are severely misinformed. The vaaast majority of 7 bolts never CW and die of natural causes. Please stop spreading this misinformation. Thanks.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
  #19
Old 09-26-2005, 08:10 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
You have no idea what you are talking about, take a hike.
To the original poster: Measure the crank endplay before you buy the car just to be safe. I have 102k on my car, I'm boosting 19psi all day long and haven't crankwalked yet. I also have many friends with 100+k and have had no problems.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
  #20
Old 09-26-2005, 08:11 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
I think you misread what i wrote, you should go back and reread it again.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
  #21
Old 09-26-2005, 11:09 AM
SLoe's Avatar
SLoe SLoe is offline
Re: Re: Re: Crankwalk question
well if it has crankwalk already then it wont drive if it does there will be a whole lotta racket comming from the engine
I had thrust bearing failure, it ran like a champ up to the day I yanked the engine and never made a single sound. I never would have known I had it if I hadn't had so many problems with the clutch (if you read, that is one of the biggest indications). I also don't think it comes from dogging your car, I would think that it is obvious it is from disengaging the clutch. So the longer you ride that clutch sitting at the stop-light the more you wear that thrust bearing. Also at start-up when there is no oil circulation, so eliminate the start switch so you don't have to push in the clutch to start the engine. It can't be inevitable or there would be no 2g's left on the road because not too many people are going to replace a motor after a few thousand miles.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
  #22
Old 09-26-2005, 05:37 PM
pinkslipRT pinkslipRT is offline
Banned
ok ur all mis informed if i am, not all just the seven bolts get it because of oil starvation its not misiformation, yes its my opinion but not just to have one from seeing it time and time and time and time and time and time again............call mitsu dealership on 19 north clearwater and ask for the tech dept. and tell them u wanna speak with gary and i will explain it to u why it will happen everytime (ON THE 7 BOLT) I NEVER SAID ALL 4G63 JUST SECOND GEN, WHY DO U THINK EVERYONE THAT KNOWS WHAT THEY R DOING SWAPS TO A SIX BOLT??????? MUST BE TO JUST WASTE MONEY
do more research before u tell me im spreading bad info,because thats not what im doing im giving u my opinion through all of my expirences
  #23
Old 09-26-2005, 05:41 PM
-Josh-'s Avatar
If any of you would like to call Gary or contact him, PM for further information because this thread has run its course and will be closed.
AF User Guidelines
Closed Thread
