#16
Keep in mind the life span of an average battery is 5yrs. My Die Hard has a 3yr replacement warranty. After that, it's prorated.
#17
Re: Re: Re: Re: Re: Re: Battery
2002 Pontiac Gram Am K&N Air Filter Mobil1 5W-30 Extended 15K 2 JL Audio 12" Subs Sealed JL Audio Box Coustic 400 Watt Class D Mono Amp Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner Polk DB750 6.5" all around Yankees Suck!!!!!!!! |
#18
Re: Battery
Just my .02$, but it seems to me like most of the car audio junkies us a yellow top.
#19
Re: Battery
A battery is one of the few things I can recommend from Autozone.
Go in and ask for a 78DT-DGN. It will run around $80 with exchange. Cranking amps at 32deg is 1000 (900cca). Warranty is 3 year free replacement, 8 year prorated. I've seen these things fry to a bad voltage regulator, get refilled with water, charged, and work like new. If you do not get the Optima, I would recommend one of these. Josh <>< |
#20
Re: Re: Battery
#21
Re: Battery
I would avoid the Die Hard Gold. I'm on my third in one year. They have a great 3 yr full replacement warranty but if you let them sit for too long they die, and they die hard. Plenty of power though (520 CCA).
'89 S10 Blazer 4.3 V6 4X4 with LOTS of rust. |
#22
Re: Battery
I went for the highest cca that I could fit in the hole . I wanted an Optima , but ended with the walmart everstart . 3 year free exchange , 9 year prorated . I have had no problems with any of mine in 6 years . Rob
#23
Re: Re: Battery
#24
Re: Battery
I think it is 950 or 980 ca but I am not sure about the cca rating . I wanted the most out of an affordable package and I don't get very cold weather too often. I really need the reserve power more , since mine sits for a week or two at a time until hunting season and bad weather . Its the backup auto , or TOY as my wife calls it .Rob
#25
Re: Re: Battery
That sounds like apretty decent battery. I will have to check that out. I have also heard good things and well bad things about Duralast, Autozones batteries. ps: On a side note, I also heard the Duralast tools are made by Snapon???? I can tell you this, the guy at Autozone held up a Snapon open ended wrench and then a Duralast one and they are the same exact thing with a different brand name on them. I believe the part numbers were the same. Just something to ponder.
