Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 09-11-2005, 11:02 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: dual exhaust
yeah thats definitely a steal. but you should understand WHY it would be pointless to use fully dual exhaust on an i-4.. if a 3" exhaust is putting out X litres every 100miles at 2k rpm, you'll need 2 1.75" (or less) pipes to have the right backpressure. how do you think that would sound?? and even the s2000 isn't a fully dual exhaust. its 2 pipes coming out of 1 muffler.
if you're thinking about having 2 tips (one on driver's side, one on passenger's), its gonna cost you 4X as much just to modify the underneath of your car to have the right length pipes. if you want twin tips, get the apex'i N1 dual. if you want a regular performance exhaust, get the N1. (imo)
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 09-11-2005, 11:09 PM
whttrshpunk's Avatar
whttrshpunk whttrshpunk is offline
There is no "right" amount of backpressure. Not in N/A motors or forced induction motorrs. Backpressure is a negative pressure in exhaust flow that results in exhaust gases(read: already burned, completely useless for combustion) and forced BACK into the combustion chamber, thereby forcing the piston to do extra work pushing that exhaust gas out of the chamber, causing less power to be made with each effective stroke. There is no such thing as an exhaust that is too big. There is a point, however, where maximum flow is reached and increasing pipe diameter would serve no purpose.
Summary: Think about it, the basic idea is to put air and fuel into the combustion chamber, compress it, blow it up, spew it out and start over. Why would you want fuel and air that has already been drained of its usefullness coming back into the combustion chamber?
95 S14
SR20DET
Full mods/part list and pics
Old 09-11-2005, 11:20 PM
xcusememisswyn's Avatar
xcusememisswyn xcusememisswyn is offline
Send a message via AIM to xcusememisswyn
Re: dual exhaust
this thread and arguement has occured a million times, if u lose backpressure, you lose tourque, i dont knoe why but you do.
i paid 579 for my s14 off nopi international, i wish i could have got one for $2** but if i had to choose i would spend the 579 again over stock, it sounds great, nice and deep and backfires just a bit at the right RPM's, at WOT its awesome.
http://www.zilvia.net/faqs/exhaust/n1/n1.asp <--sound clip, check it
RB20DET, 260whp, Drive to Destroy.
Old 09-12-2005, 12:03 AM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Re: dual exhaust
I'd wanna get it to, but seems pricey for mild steel.
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 09-12-2005, 05:54 AM
Adam_rex Adam_rex is offline
Re: dual exhaust
well i was really askin how the duals installed. on passanger side my gas tank is right in the way. and i dont plan on putting 2 cannon 3.5" tips on it. and will it cost alot is my real question.
Old 09-12-2005, 06:00 AM
bleh no edit. well anyway. this is what i am thinking of putting on. 2 of these.
http://cgi.ebay.com/ebaymotors/HKS-D...QQcmdZViewItem well not this exactly but something like it.
Old 09-12-2005, 11:07 AM
slideways...'s Avatar
slideways... slideways... is offline
Re: dual exhaust
ok to clear it up...the only torque you would lose with a bigger exhaust is torque acquired from the resonance tuning of the pipes
you can get max torque out of the engine with a wide open exhaust, but a few more ftlb can be gained by using a resonance tuned exhaust OVER what your engine can make. most high quality exhaust systems use this method to boost low end torque so they dont make less hp than a wide open system(read: high quality as in not tsudo, ect
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 09-12-2005, 11:08 AM
Re: dual exhaust
I still don't get why you wanna do it.
-Jonathan
Montreal, Canada
Old 09-12-2005, 11:10 AM
sidewayzS13's Avatar
sidewayzS13 sidewayzS13 is offline
doin it sidewayz
Send a message via AIM to sidewayzS13
Re: dual exhaust
im gunna say its not worth the money you will put into it
Originally Posted by Muscletang
I say let it run its course. Most women experiment with things. They'll try something whether it's mind altering drugs, going down on their best friend, an Emo song, or plastic surgery.
Old 09-12-2005, 11:27 AM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
ok...
Im gonna have to say that its not really the resonance that cause you to get tq. Its back pressure that gives you the low end torque.. Now too much back pressure and you have a bad problem. Sure Resonance can mean back pressure but resonance can be achieved without backpressure.
Old 09-12-2005, 04:23 PM
D-Bo's Avatar
Re: dual exhaust
maybe its not a specific size that gives the 'right' amount of bp, but there is a point where you can have too little or too much so that you're not producing efficient power. i'm not sure if the physics of dual exhaust on a 240sx evade the PRINCIPLES of physics but i don't see how it would help. unless you want to go rice can dual exhaust with one pipe from the engine, then ok, make sure the rice doesn't stick to the pot.. just go with any cat back for over $300. that way you know you're buying a quality product. i suggest the apexi n1 or n1 dual.
Old 09-12-2005, 05:01 PM
yea i planned on putting a header and splitting it about half way past the car. i just like the dual exhaust look. plus i was thinkin about doing a vg30dett or a rb swap.
Old 09-12-2005, 10:06 PM
Re: dual exhaust
rb's are straight six, no need for duals
Old 09-13-2005, 12:27 AM
Re: dual exhaust
no backpressure does NOT give you torque
i wish i could cast the spell of wisdom upon all those infected with that old school domestic ricer myth
if you still insist that it does please try to explain it with physics or some logical manner. dont use the sucking thru the straw theory cuz thats total bs
Old 09-13-2005, 01:27 AM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Resonace Tuning is for headers... dont kid yourself into thinking that any part for a KA or SR is resonace tuned.
The case of backpressure is guilt by association in that stream velocity is what makes torque. to get velocity you need pressure. Velocity makes torque by giving the exhaust momentum and it creates a scaveging effect inside the cylinder at a certian piston speed. the speed this happens is determined by piping diameter... large exhausts will stagnate at low speeds and will start to scavenge at a higher RPM but smaller exhausts will scavenge at a lower RPM but then choke at a higher RPM.
