| Latest | 0 Rplys |
#16 | ||
![]() Join Date: Dec 2005
Re: Re: Passlock System
Ray Proud Member of The Anti-Passlock Club Last edited by raycorri; 02-25-2006 at 09:31 PM. |
#17 | ||
AF - Advisor
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2005
Re: Re: Re: Passlock System
Gm uses 4-5 different anti theft systems depending on year and make and model. The wrong disconnect or jump can shut down or wipe out the pcm or body module or theft module. I know it takes money to fix the system if it gives problems and the dealer do not help any. They to often just replace everything. And a lot of people just want to bypass the hole sysem. When a lot of trouble is just a simple dirty connection or loose wire or pcm or body module or theft module or what ever. When a system acts up it should be tested out first thing. To find out for sure what it is. The wire disconnect you showed us may fix the problem on some but it depends on the problem or what it is. I can not see it being a fix all for all modles and systems. On that GM Upfitter integeration Truck Group UI bulletin # 26 is it from GM or a GM factory bulletion or from other source? I can not find it in any of my repair programs. MT
#18 | |
Re: Passlock System
I have seen the same no-start on a 2001 Impala -- I actually called the dealer, and they told me this "procedure" over the phone:
Turn Key to on position, wait 5 minutes, turn key to start.... Vrooooom! It worked! I told the dealer, and he suggested I bring the thing in anyway because it wil probably "happen again" This was the first time, so we'll wait and see... Anyways, thanks for the info in this thread, it really helped me.... |
#19 | |
AF - Advisor
Re: Passlock System
SpinnerCee
It was giving you a warning. You need to get it tested out. You were luckie and got it to override and start. The next time it may or not overide. But again proceed with caution on trying to bypass or fix it. The Impala 01 is a long way from a 01 malibu that only has one theft system. The 01 Impala has 3 different anti theft systems. Passlock TM system Content Theft Deterrent CTD system Vehicle Theft Deterent VTD system http://members.troublecodes.net/crunch/01impala.pdf First step in repair or check out is to get it on a body capable scanner and check for codes past and present. And as soon after it acts up as you can get it checked. Good Luck MT
#20 | |
AF - Advisor
Re: Passlock System
SpinnerCee and 00-05 Impala Monte Carlo owners.
Here is A GM tsb that may help on anti theft no start. http://members.troublecodes.net/crunch/Impala%20.pdf MT
#21 | |
AF - Advisor
Re: Passlock System
#22 | ||
Re: Re: Re: Re: Passlock System
Technical Bulletins The Technical Bulletin Process informs manufacturers of any product changes or issues that may affect their designs. The need for a bulletin may come from: a. A GM Vehicle Engineering source such as a Mock-up review, where a product change requires an upfitter design or manufacturing modification; b. One or more upfitters who have expressed repetitive concerns or experienced a frequent vehicle difficulty. The investigation process for a bulletin is similar to a Hotline request in that an Upfitter Integration Vehicle Engineer is assigned the responsibility of researching the situation; however, a question or concern only becomes a bulletin when it is judged to affect all upfitters or an entire vehicle platform and any resolution needs to be communicated to every concerned party. Engineering drawings that illustrate the issues and highlight corrective action measures or possible redesigns are gathered, the Bulletin goes through a review and approval process by all affected areas within GM Vehicle Engineering, and is then published and distributed to the entire upfitter community. So, I guess that bulletin came from GM Vehicle Engineering.(Dated 4/22/99) The upfitter community appears to deal mostly with GM Fleet Trucks and Vans. Anyhow, Thanks for your continued input! Ray Proud Member of The Anti-Passlock Club |
#23 | |
Re: Re: Re: Re: Re: Passlock System
#24 | |
AF - Advisor
Re: Passlock System
Raycorri
Thank for posting back with the info on the upfitters bulletin. It would be nice and a lot simpler if the manfactures would make the anti theft systems where you could turn them off or disable them if they give problems or if a person does not want them. Good luck MT
#25 | ||
http://www.insurorsservicebureau.co...ical/ISB_QA.pdf PASSLOCK I, NEW GM SECURITY SYSTEM(Page4) http://www.techtrainproductions.com/bulletin/ttb_14.pdf GM TEN-CUT BITTING: A STUDY IN CONFUSION (Page 7) http://www.techtrainproductions.com/bulletin/ttb_15.pdf Ray - Proud Member of The Anti-Passlock Club |
#26 | |
Re: Passlock System
I have been struggling with this Passlock II (Malibu 1998) issue for the past year, and it seems to be getting worse. I am thinking of going with raycorri's method as I don't care to have the "sercurity" or having the theft-light on while driving. My only concern is the possible battery issue MT-2500 brought up, I am not entirely sure if this was concluded to be irrelavant or not. Any one have any thoughts on this?
I am hoping to save some time, money and hassle of having a dealer fix this issue. If anyone knows a knowledgable and reasonably priced dealing in the California Bay Area I might be willing to spend to fix it. Thanks to everyone, especially raycorri, for this thread. I know this thread has helped many owners of Passlock systems. |
#27 | ||
Re: Passlock System
NOTICE Any condition which removes battery power from the Vehicle Control Module/Powertrain Control Module (VCM/PCM) (e.g. dead battery, disconnected harness connectors, etc.) will prevent the vehicle from being restarted. If the engine exhibits a “cranks but will not start” symptom, check to make sure that the modification switch is in the OFF (contacts closed) position. That last little bit should probably read (as it pertains to us):If the engine exhibits a “cranks but will not start” symptom, place the modification switch in the OFF (contacts closed ) position. So, some questions you will need to ask yourself, at least from my point of view are: How many times in the past has your battery died or have you disconnected your battery? I had to have my car towed way more times for passlock issues than for a dead battery or disconnect. It is my hope that others like yourself will report back to this thread with successes or failures pertaining to this modification. (Months or even years from now!) Good luck and I'm sure you will make the right decision based on your particular situation and point of view. Ray Proud Member of The Anti-Passlock Club Last edited by raycorri; 02-25-2006 at 09:36 PM. |
#28 | |
Re: Passlock System
I wish that i had read this before my car stopped starting. My secerity light flashes. I can not start my car. I took it to a car repair shop. They tell me that I need new ignition module. Is there any way that i can get around replacing the module now that my lite is flashing or do I have to replace it. t
#29 | ||
AF - Advisor
Re: Passlock System
Before anybody can help you on your car. We need the year make and model and eng and trans and mileage. And also what the garage found. Did they find a ign module on the eng/ign/coil spark system or the the anti theft system module/ign key switch bad? The bypass on the anti theft system that was talked about only pertains to certain models and certain anti theft systems. Also the best I understand it it has to be done with the engine running. No run and you may not be able to perform that certain bypass. Have you tried leaving the key on 10-20-30 minutes to over ride the system and see if it will start? If the security light is flashing and you have a no start I would suggest you get the codes out of the body computer first. And post them back along with the make and model and year and engine sise. MT
#30 | |
Re: Passlock System
I have a 1997 Oldsmobile 88. It has the passkey II (key with resister in it)system on it. 3800 engine and auto transmition. The security light flashes and will not turn over. The battery has gone dead and will not take charge anymore. the shop did not tell me of any codes. they said they would have to install ignition module of some kind. will not be able to find out for sure until monday.
