Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-10-2005, 09:36 PM
JOET/CAMRY JOET/CAMRY is offline
Re: 1994 Camry XLE 4cyl
Originally Posted by qwerty4321
i just want to say thanks for everyones advice, and all i did was clean out the IAC, there was lots of carbon deposits.
Hello qwerty4321, did you strip the heads of the last 2 screws that hold the IAC valve in place? I think thats what you tried to say on your previous post. if you did, you could still remove them using a small pair of vice grips. once there removed you can replace them with new screws or cut a slot in the head of the screws (using a dremel with a cutting wheel attachment or use a hacksaw). then just reinstall them using a standard slotted screwdriver instead of a phillips screwdriver. hopefully you were able to clean the IAC valve in place well enough to solve your problem with your car.
JOET/CAMRY
Old 09-10-2005, 10:37 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
You're welcome
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
