Old 08-30-2005, 01:41 PM
Saudade's Avatar
Saudade Saudade is offline
Re: 1990 cherokee won't stay running
I just checked it. It works for me.
Old 08-30-2005, 05:56 PM
Po Pilot Po Pilot is offline
Send a message via ICQ to Po Pilot Send a message via AIM to Po Pilot
The CPS - crankshaft position sensor located on the bellhousing on the right side of the engine (if looking at it from the front). Souns like its gone bad or the wiring has gunked up.
Old 08-31-2005, 08:25 AM
89ltd 89ltd is offline
the page should come right up when you click on it, I just book marked it for myself.
Old 08-31-2005, 10:42 AM
Johnk_56 Johnk_56 is offline
Re: Re: Re: Re: 1990 cherokee won't stay running
Originally Posted by Dale Aeppli
http://www.4x4getaways.com/XJRelays.jpg Here is a site that shows the relay Hope it helps Dale
Found it...it was .net that I needed.
Thanks, this is very helpful....
Old 08-31-2005, 10:43 AM
Thanks, I will check this also.
Old 09-06-2005, 03:23 PM
Re: Re: Re: Re: Re: 1990 cherokee won't stay running
Originally Posted by Johnk_56
Thanks, I'll check it out...
I found the site and replaced the fuel pump relay. It clicks when I try to start the Jeep and it starts and then it still dies.....
I am running out of ideas here....
Is there a sensor that measures the crankshaft movement? Someone mentioned this to me. If there is, where would it be, maybe it needs to be replaced also.
Thanks
Old 09-06-2005, 03:25 PM
Thanks, someone else mentioned this. Do you have a picture or site that shows this? I'll try to find it tonight. I replaced the fuel pump relay but that didn't fix the problem. I will try to locate the CPS and check it out.
Old 09-07-2005, 11:37 AM
runuover runuover is offline
Re: Re: Re: Re: Re: Re: 1990 cherokee won't stay running
mine did the same thing the other day and it turned out to be the plastic egr valve . try unplugging that and see if it runs better.
Old 09-09-2005, 03:21 AM
Kronyk Kronyk is offline
new to this forum, but love my cherokee's :P uh, 2 ideas for yah, as i have come across the same prob 2x in my cherokee expierence... 1) sounds simple, chasis ground from battery? easy mistake... 2) TPS throttle positioning sensor, controll's choke/idle as well...
Old 09-26-2005, 12:46 PM
Thanks for the ideas...I will check the ground. Where is the TPS located?
I just replaced the CPS and it runs better but still dies after a short period of time.
Old 09-27-2005, 09:00 AM
I cleaned the ground and cleaned the TPS, the car will start but still stalls. Runs really rough like it's not getting fuel then stalls.
This is driving me crazy.....
Old 10-10-2005, 11:09 AM
Well, I replaced the TPS and the car starts and runs rough and then dies when idleing....now what? This is making me crazy...
