Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 09-23-2005, 02:12 AM
centervilledon centervilledon is offline
Re: noisy fuel pump? bad tape player
Thanx to all that rrote trying to help. I did get the shocks changed and found it easy except for one bolt that was rusted in. It took a lot of pounding with a heavy hammer to get it out. I do have the radio out and that was easy to do. My local junk yard will sell me a radio cassette player for $35 if I take it out myself. He says he has 3 Fieros out in his yard. So I will try one as soon as the mud dries up a bit around here. I think I'll wait til next spring to work on the AC. Summer is pretty much over here. I'll probably take it in to a local shop and have him remove the freon and check ffor leaks. Then find out what is appropriate oil to add and ask about a sealer. The fuel pump has taken a back seat also. Its noisy but still works. My problem right now is oil dripping from the motor. I can't tell from under the motor where it is coming from. I plan to tighten the pan bolts as soon as I get a long enough extension. Other than that I can't see anything else I could do. Does anyone know where the common places that leaks are on the V-6? Don
Old 09-24-2005, 07:05 AM
Thanx for the advice on the fuel pump. Since it is still working albiet noisy. I'll let that slide awhile. I bought a radio cassette player for $35 out of a Fiero at our local auto salvage yard. Everything matched. Unfortunately the dial won't light up. It just flashes some digits once and a while. The tape player requires a requires a push on one of the knobs to get it going. If you don't, it just makes a click, click, click noise continuosly. There was an extra single wire with a connector on it coming out the back. I can't figure out what that is for. Anyone know? Don
