Old 08-27-2005, 07:58 PM
mrfixit64857's Avatar
mrfixit64857 mrfixit64857 is offline
Re: Oil Change
I just had to read this thread for the fun of it
What is life, if not to be laughed at... or caught in a Ford?
have mercy on me...I gave Oil today!
Old 08-28-2005, 03:49 AM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Re: Oil Change
Originally Posted by AndrewKumquat
I also think you guys are giving me instructions for the 2.2L engine, I have the 4.3L.
Your truck must have the new oil in it. It lasts the life of the vehicle so the manufacturer deleted the drain plug.
Just kidding!! Take it to a shop!!!!!
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
Old 09-09-2005, 07:13 AM
KHFINLAY's Avatar
KHFINLAY KHFINLAY is offline
Re: Oil Change
On my 4.3 vortec the drain plug is to the back of the metal guard protecting the oil pan. Look to see the metal protective plate below the engine, follow that to the rear middle and you will see a thingy that you have to remove with a socket. There is also a front protective plate that has an access door for the oil filter. Turn that screw 90 degrees and force thet door open as it is spring loaded. What probably is your problem is that cars dont have that skid plate under them because they are not built for off road. Your blazer has metal plates to protect everythimg so they wont be easily damaged when you go offroad. Dont feel like an idiot I can see where it seems strange since normally below a car you would cee the oil pan and oil filter without metal plates over them. Hope that helped
98 Blazer LT
154,000 miles
Drives like a gem
Approx 18 mpg
Current mods
7 " monitor in passenger headrest, working on drivers
Cassette player replaced with DVD, audio not connected yet
Lots of detailed pics coming soon
Old 09-09-2005, 04:35 PM
Blazerboy1287's Avatar
Blazerboy1287 Blazerboy1287 is offline
Send a message via AIM to Blazerboy1287 Send a message via MSN to Blazerboy1287
Re: Oil Change
Okay, the bolt you were talking about, the one "torqued down like hell" is the one for the drain plug... i just changed it... don't use an open ended wrench, use a ratchet, with perhaps a breaker bar if you can't get the leverage... the socket size is 9/16, and then the remote oil filter for the 4wd models is located behind the door that you open near the front. Hope you managed to change the oil. and if you have the 95, make sure to use 4.5 quarts, no more, and no less!!!
Black 1995 Blazer LT 4 Door 4x4 *SOLD*
@110000 miles
3-inch piping with a Flo-Pro V-Force Muffler
97 Eclipse GST (Burgundy) (powered mostly by Ebay)
123000 miles
Short throw Shifter
Ebay true 3-Inch Stainless Steel Catback
Ebay Intake w/ K&N filter
GSX dual piston upgrade
Powerslot Rotors
Akebono Ceramic pads
All synthetic fluids
"It is only after you have lost everything that you are free to do anything."
-Tyler Durden
Old 09-09-2005, 06:39 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Oil Change
dont use anything thats not a closed six point for the drain plug
Old 09-09-2005, 08:03 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: Oil Change
Huh, 9/16th's you say? I guess the previous owner had the pan stripped out on mine. Mine goes on and off with a fresh copper crush gasket, using a 13mm Flare nut wrench. Can't get much more of a snug fit that way, and it's not too long so you set it's torque too tight. Otherwise, I *think*, I have to look it up in my tables; but the pan bolt should be snugged to 25 foot/lbs with a torque wrench. I have a breakaway style so long, it doubles as a cheater, but there is no more precious tool in my collection. From setting wheel lugs to precise torque, to making sure you don't squash and cut gaskets, there is nothing better!
