Old 08-22-2005, 12:15 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
nice work. ill be watching this progress carefully for tips as F1's arent my speciality im dreading having to remove the seat belts on the 99T but over all accuracy seems a bit better then your 4/4 seat. keep the progress coming, its great to watch!
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
Old 09-28-2005, 05:32 AM
jaykay640 jaykay640 is offline
O.k. here finally comes an update. It's not that i haven't been working on the model.....it just wouldn't have shown in pictures really:-)
As i mentioned in my last post i thinned down the whole cowling. This took about 15 hours of careful work alone. It's so thin now, the surfaces are flexible and can be pushed in. That's of course not the goal but may give you an idea.
I then scratchbuilt the inserts on the sides of the cowling. I put the kit piece ( early season big hole ) for comparison.
On the inside it looks like this:
There will follow another piece that leads towards the radiator. That's a seperate component on the real car and for easier painting and decaling i decided to do it the same on the model.
This is a view of the thinned rear end of the cowling. It's actually quite tricky to take pictures of this white plastic stuff under the light conditions i have in the evenings when i work on the model:-(
I then added a plastic strip to the lower edge of the cowling to match the modified undertray.
At this point i went on to fit cowling and undertray. Originally i wanted to keep the cowling in one pice as long as possible but it turned out that didn't work too well so i cut the nose piece off along the molded shutline.
On both pieces i added flange walls...
...and then worked on the underside of the nosebit and made it fit nicely to the monocoque. I put the blue tape to protect the wing bits from bending or breaking off.
Now when the pieces of monocoque and cowling are put together there's only a thin gap that should be even smaller once the pieces are CF'd and painted (...hopefully:-)
The cowling unfortunately has a bit of tension and doesn't slide on and stay perfectly where i want it to, so i will later add some pins where the real car has it's fasteners on the sidepods to make it fit tighter.
While doing all this test fitting i realized there was another problem around the cockpit. The opening in the cowling was wider then the one in the monocoque.
Since it was pretty low in the sideview as well i decided to add about 1mm and also new inner walls to change that.
This is only one place of many where the proportions of the kit don't exactly match the real car but changing everything would be a bit too much and actually if you don't have the reference pictures for comparison nobody will notice:-)
So much for now!
Old 09-28-2005, 05:55 AM
sjelic's Avatar
sjelic sjelic is offline
Re: Eighties Contest Entry: 1988 McLaren MP4/4 (and Introduction)
So much work, if I didn't know I would have said that it was Revell kit since it needs so much improvement , just kidding, I love when someone takes so much care about the details, great and throughout work on this one.
Sasa Jelic
SCALEMAKERS
Old 09-30-2005, 12:12 PM
klutz_100's Avatar
amazing build to watch and admire!
Your attention (and devotion ) to detail is as awsome as your skill
Old 09-30-2005, 04:40 PM
robrex's Avatar
robrex robrex is offline
fantastic detail work! I can't wait to see more progress!
Rob
Old 09-30-2005, 05:20 PM
Zlaja_'s Avatar
Zlaja_ Zlaja_ is offline
Send a message via MSN to Zlaja_
Man you must have nerves of steel! Keep the updates coming!!
Old 10-04-2005, 03:11 AM
Thanks for the comments guys:-) So far my nerves actually haven't been tried on this one. As i said i kind of know now where trouble most probably will strike from building the MP4/8 ( which isn't finished yet ) and others like a Lotus 25 that has stalled after it's 3rd set of scratchbuilt exhaust pipes that still don't work ( dohhhhh!!).
After a weekend with some good modeling time though here comes another update:
First up a reference picture of the cowling frontend i forgot in my last post:
I carried on with the inside of the cowling and added some surface details ( i.e. dodgy CF layup ). Here's a picture of the real one:
...and this is the model. I added a piece of 0.2mm plastic sheet in the front and some polyester putty. It does make me feel quite stupid to first sand those surfaces nice and smooth and then mess them up again....but that's the way it goes:-)
In the rear part of the cowling i added those two pieces made from 0.8mm plastic sheet.
They seem to be heat shields and will later be covered with chrome foil. I forgot the picture where they are mounted but here is one of the real car:
The cowling is now ready for some primer but first i'll build some more bits. First up were the sidepods. After cutting off the kit pieces in the beginning i scratchbuilt them from various thickness plastic sheets. I do two pieces per side as on the real car.
The real one on the right hand side:
...and the built up piece with the top and bottom bits copied for the left hand side:
Now this is the major difference between the early season MP4/4 as it comes in the kit and the late season version i'm building. Instead of the periscope airducts sticking out of the cowling the turbos are fed internally. The turbo intercoolers are smaller and the intakes run around them on both sides of the car so the sidepods are different here:
This is a picture during buildup:
And this is the finished bits with some tiny flanges:
Finally an overall view with all sidepods done.
They took longer to make than i first expected....but in fact that happens most of the time :-)
Next up in this area i have to build the radiators and connect them to the engine but there's more to do on the monocoque first!
Cheers
Old 10-04-2005, 03:25 AM
klutz_100's Avatar
longer than expected? I'd still be doing them in 3006 LOL BRAVO
Old 10-04-2005, 04:07 AM
sjelic's Avatar
It is getting better and better, stunningly clean scratch work!
Sasa Jelic
SCALEMAKERS
Old 10-04-2005, 06:31 AM
generationx's Avatar
generationx generationx is offline
Awesome
Old 10-04-2005, 04:14 PM
robrex's Avatar
Another fantastic update! I am amazed again at the scale accuracy you are achieving! Excellent work!!
Rob
Old 10-04-2005, 04:19 PM
Martin S's Avatar
Martin S Martin S is offline
Some nice styrene sculpting there !
Latest progress:
Ferrari F40 LM Fujimi 1/16 and Porsche 959 Fujimi 1/16
Finished:
1940 Ford pickup and Lotus Super Twelve
Old 10-04-2005, 08:50 PM
g00eY's Avatar
g00eY g00eY is offline
welcome to AF! it looks great so far!
Old 10-05-2005, 12:10 AM
geronimo77 geronimo77 is offline
AutoWeek Magazine Vendor
Send a message via MSN to geronimo77 Send a message via Skype™ to geronimo77
This is really nice work. It is good to see people who are aware of details.
I plan to build the F189 do you have any idea where to find such nice reference photos?
Old 10-12-2005, 05:12 AM
Sennake's Avatar
Sennake Sennake is offline
I have TONS of respect for you, man! Tons of respect!
Increadible work!
I will follow this thread very closely. And probably build my MP4/4 again using your tips and techniques as well...
* WWW.SENNAKE.BE *
