Old 08-15-2005, 01:36 PM
FormulaRX7's Avatar
FormulaRX7 FormulaRX7 is offline
Send a message via AIM to FormulaRX7 Send a message via MSN to FormulaRX7
Re: A few questions about shift kits.
So... i can get a manual transmission to replace my automatic one? The dealers and shops ive talked to said i couldnt do that because the parts to the vehicle are set in different then they would be for a manual... also... how much does a manual trans cost? (including installation)
When your the only one on the road, that's all that matters...
Old 08-15-2005, 02:22 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Yes, you can convert to a manual tranny. Just wouldn't be worth the time or money though. The only thing I can think of engine wise that you would need to swap out would be the flywheel. Because automatic transmissions connect to a different kind of flywheel as to the one the manual tranny uses. Then you would need the manual tranny, with the pedal assembly. I probably overlooked something, but those are the basics. Not sure of the cost on installation, but you can probably find a cheap tranny on eBay.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 08-15-2005, 04:47 PM
FormulaRX7's Avatar
i dont know... i mean ive heard a lot from other shops and friends that a manual vehical can always out preform an auto any day, and besides after recovering from a drift with a manual you dont lose nearly as much speed as you do with an auto, or so ive heard. But then again... a turbo would fix the lag from the speed loss and a 25 shot of nitrous would solve the turbo lag problem... all in all though... i really do want to put a manual in the car. Mainly for durability reasons none the less. Any thoughts?
Old 08-15-2005, 08:14 PM
blindeyed's Avatar
eBay aDdict™
Manual is always good for drifting. Auto's suck when it comes to that, no doubt about it. But I believe John (FormulaLT1) mentioned a couple of times on the forum that the auto's are actually faster in the 1/4 mile. If your willing to put up the money to do the swap, then go for it. But I'll warn ya, it's gonna cost ya a pretty prenny.
- Jason
Old 08-17-2005, 12:33 AM
FormulaRX7's Avatar
ah, kk thanks... i'm not much of a fan of 1/4 mile i'd rather take a course... so.. looks like i've gotta start saving for that tranny... yay...
Old 08-17-2005, 05:46 PM
Matt365's Avatar
Matt365 Matt365 is offline
Send a message via AIM to Matt365
Re: Re: A few questions about shift kits.
Originally Posted by blindxeyed
Why would you want to do that? The 4L60-E automatic transmissions aren't designed to have the gears be manually selected like that, and in the long run, will really decrease its life.
Its true that it will decrease its life, but it is better to manually shift it then to stick it in drive and start it out hard. Will tear up faster from u starting out 2 hard in drive.
Old 08-18-2005, 03:48 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
hay not to talk shit but have any of you read your owners manuels it will tell you under sertain conditions to manualy shift yer auto trans and if it was bad for yer car they would tell you not to do it or it would not be mentioned at all true the trans is computer controlled (this will prevent damage
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 08-18-2005, 03:57 PM
blindeyed's Avatar
eBay aDdict™
hay is for horses.. lol j/p man. First off, I don't have an owners manual. 2nd, prolonged use of manually selecting gears will decrease the tranny's life. The transmission is an automatic. Hence, it selects which gear would be suitable for current driving situation. If you select a gear other than the one which would be more suitable for the situation, than that will have a negative affect on the transmission. Regardless if it's computer controlled.
- Jason
Old 08-18-2005, 07:19 PM
man ive down shifted to help stop faster in the snow ive held it in to a lower gear to go up hills i mean shit man what do you think happens when you stomp the gas and the car takes off
just in case you didnt know the damn thing down shifts
Old 08-18-2005, 11:37 PM
blindeyed's Avatar
eBay aDdict™
mmk, well cool your jets man. No need to be getting worked up over it.
Yes I did know that it downshifts.. It's a transmission, I would hope that it would. I'm just passing what I've heard from others onto you. If you think that manually selecting gears is fine for all out daily driving, then so be it. But I'll keep it mine in "D" and only manually select gears when the need is necessary.
- Jason
Old 08-20-2005, 07:20 AM
FormulaRX7's Avatar
Oh another question, a friend of mine and myself were discussing what ive been trying to get answered here and he said that its called either of these things a "shift kit" or a "quickm shift kit" now he says they are the same thing and what he is talking about is what i wanted to do. Can anyone elaborate?
Old 08-20-2005, 09:53 AM
sorry man not trying to be dick just going from things ive seen and done
not here to argu or make people mad
Old 08-20-2005, 11:26 AM
Matt365's Avatar
well, im not really satisfied with the "yahoo" shift kit i had installed. yes, you can tell its in there, but just barely, it replaces 2 of the ball bearings in the shifter with 3 springs i believe, its designed to shift harder, but barely noticable on a v6.
Old 08-20-2005, 03:44 PM
blindeyed's Avatar
eBay aDdict™
What you want to get is the TransGo 4L60-E shift kit. Here's a review and install guide about it. It also explains its purpose and the benefits from it:
http://www.gmhightechperformance.com...07htp_projls1/
- Jason
