| Off-Topic Talk about anything other than cars. |
#16
Re: Guys, I need a vented hood.
I want a pic...... upload asap please..... And I might get that exhaust wrap..... Gotta read more about it
1998 Eclipse GSX (Sold) ![]() Act 2600, Apexi 3" downpipe, 3" exhaust, Hks 3"-5" muffler, Greddy TypeS BOV, Autometer Boost/Vac & Air fuel Gauge, Garrett T3/T4 60-1 turbo (Only boosting 15 psi) Tial 38mm Wastegate, Spearco FMIC, Greedy Profec B2, HKS Turbo Timer Type, Dejon Intake/K&N Air Filter, DSMLink, Eprom ECU, 950cc Fuel Injectors, Walbro 255 HP Fuel Pump, Aeromotive FPR, Drilled/Slotted Rotors, B&M Short Shifter |
#17
I would think you could cover the vents with a sheet of metal if you do the grayforest mod to your hood, just to keep out extra water when it rains.
#18
Many people just run a CF hood and drop in a Carbonwerks/RRE hood vent front and center. People have logged significant drops in coolant temps and charge air temps while road racing thanks to the adde flow through the radiator and FMIC. This is the reason I meant to do this to the 2g for years. The engine bay is like a big parachute, catching all the air creating a high pressure area, making it difficult to get good air FLOW through the FMIC/radiator.
Luckily the EVO comes vented stock, and coolant temps never get over 183 and the FMIC must be working if I can run 12.7:1 with extra timing at 40 lbs/min and not knock, on pump. I recomend a hood vent for sure! Water gets in there, but if Mitsu decided it was safe enough to still give a 100k mile warranty, it must be ok. The other downside is that all the heat that is released gets pulled into the HVAC system. If you turn the HVAC knob to the coldest setting but dont run the AC, you still get hot air
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
#19
well his Mitsubishi isnt an Evo so i would worry about the Rain. i wouldnt want anything under my hood cracking open.
Austin - 95 GSX . -K&N FIPK. -Ijnen UICP + Greddy RS BOV. -Rota Slipstream + yokohoma Es100's. -Tokico HP Blue's + Springs. -Power Slot PRO rotors ( slotted+Dimpled ) with Hawk HP Pads. -Manacore Wires. ( got a 20g and the works in the clothset )
#20
Re: Re: Guys, I need a vented hood.
Make and model will change thermodynamics and reactivity of metal. Look into the CarbonTrix vents, like Kevin mentioned, and also try and figure out why you engine bay is so damn hot. Tighten the WG dump tube, manifold studs (to spec!), etc and make sure you don't just have a hot leak going on.
Kris 2012 Genesis Coupe 2.0t |
#21
My cock dad took my damn car too work, lol POS. I'll picks up of the hood tomorow, sorry.
#22
Ok I just took a look at those hood vents and they look like something that might work for me. But (I know I'm an Idoit) how do you get the vents functional on a hood? Do you have to do some custom cutting? And If I were to get a Carbonfiber hood and do some cutting, wouldn't it come out all crappy like becuase of how the Carbon Fibers would shed?
Also, If I'm looking into getting a Carbon Fiber hood and putting Carbon Fiber vents on it, what would be the problem with getting just a carbon fiber hood with vents already in the hood? Sorry, I know the performance stuff, But have no clue about the body mods
#24
I have heard a lot of good talk about the VIS CF hoods. It is said that they last through the heat of the turbo unlike some sold on ebay that melt sometimes. I think Shpyders hood is a VIS CF ( not sure) but most VIS hoods come with vents in em.
Weight wise you car will also be lighter with CF hood. Good luck man |
#25
I suggest using the heat wrap if a hood/hood vents are out of the question... here's a link to some stuff I have...
http://designengineering.com/products.asp?m=sc&cid=3 I believe they also have turbo wraps...been a while since I have been to that site...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan |
#26
I wouldn't recommend wrapping exhaust in that stuff, much less a manifold, etc. It traps mouisture and causes cracking and other wonderful things.
#27
#28
Hey, that hood looks pretty good! I could really see that going onto my car hehe.
![]() 2006 Wicked White Evo IX GSR 323 awhp / 311 tq. (Dynojet) http://www.projectevoix.com http://www.4WStuning.com 99 RS < 98 GSX < 06 EVO
#29
Why thank you - Its functional too, and the air would be thrown right on top of your intake filter, but its expensive as fuck.
#30
