Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 08-13-2005, 10:57 AM
Mines69Olds's Avatar
Mines69Olds Mines69Olds is offline
Send a message via AIM to Mines69Olds
Re: Re: Automatic Vs Manual Question.
Originally Posted by neatofrito1618
no its like 10 or 15%
Ok I wasn't really sure I just heard some people talking about it and I wanted to know for sure. Thanks
Old 08-13-2005, 11:03 AM
TheStang00's Avatar
TheStang00 TheStang00 is offline
well if it has a c4, those are notorious for taking a lot of power.
Old 08-13-2005, 11:10 AM
What are you driving Stang. Auto or Manual and how is that working out for you?
Old 08-13-2005, 11:28 AM
TheStang00's Avatar
i have a manual and i love it
Old 08-13-2005, 11:46 AM
What does your stang have in it and what mods have you done to it?
Old 08-13-2005, 06:07 PM
TheStang00's Avatar
well see i dont have anything near 350hp... i just got the 190hp 220tq v6. but i can tell you that the same type of mustang as i have with a auto is slow as balls, runs like a 16. mine is a mid 15 car. although i havent actually run it at a track myself.
Old 08-14-2005, 04:53 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
All autos are not created equal, meaning drive line loss is different between any of them. A C6 auto will have about 10% more loss than a C4, and a powerglide will even have less loss than a C4.
Give 350hp as the standard, it would be very close with a C4, but with a C6 the manual should win every time, as long as the manual is shifted correctly.
C4 loss is around 22%, but that also depends on the power put down by the engine, the more power, the more loss. Ballpark figures of course.
A T5 will have around 17%, but once again, it depends. Going synthetic helps a lot as well.
Like I have said, if I am building a 1/4 mile car with over 400rwhp, I am going with a C4. Not mention, they are cheaper, and easier to drive on the street with really big hp levels, as long as you don't mind swaping out the converter from time to time.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 08-14-2005, 08:06 AM
neatofrito1618 neatofrito1618 is offline
Send a message via AIM to neatofrito1618 Send a message via Yahoo to neatofrito1618
is there anything else besides oil and a torque converter that could get more rwhp? and could u drill wholes in the auto transmission to get more transmission fluid to make it shift faster and harder?
Old 08-14-2005, 05:12 PM
SkylineUSA's Avatar
Drill holes? Watchu talkin bout, Willis?
Get a manual valve body, all the pressure all the time, also it depends on your toque converter.
If you want more rwhp, go boost and turn up the psi
Old 08-14-2005, 08:56 PM
i was talkin about drillin wholes in the valve body. my dad said he used to do that in old cars to make it shirt faster and harder and i was just wonderin if u could still do it with the newer cars cuz i havent heard of anyone doin it.
Old 08-14-2005, 11:37 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
You do that with some of the aftermarket shift kits, I did that with a B & M Transpak. It's just some modifications needed while installing the kit. Some of the holes needed to be widened, in order to increase pressure.
If your interested in that, here is the link
http://www.bmracing.com/index.php?id...s&sid=2&cat=13
BUT get someone DAMN GOOD at AUTO's to work on it!!!! Out of the 13 or so auto's that I installled it in, I personally fubarred 1 of them, all because I was in a rush, and got to cocky....
My ride at my site Silverstangs.
Old 08-15-2005, 12:08 AM
SkylineUSA's Avatar
Like silver said, widened , not just holes
If you run a manual V/B, there is full pressure on every shift. I picked up my reverse manual V/B for $100 on the corral, so you can get good deals.
Old 08-15-2005, 09:10 AM
TheStang00's Avatar
i have actually heard about that hole thing too...
Old 08-15-2005, 09:51 PM
Re: Re: Re: Automatic Vs Manual Question.
do they have it for a 02?
Old 08-15-2005, 10:54 PM
Re: Re: Re: Re: Automatic Vs Manual Question.
Yes the application number is 40266 - Ford, 96-'04 4R70W and it is called the Shift Improver Kit. You also want to get the Cast Aluminum Pan 40291 which if I remeber was another 3 more quarts of tranny fluid. Also get yourself a Hypertech or some type of hand held programmer. Last but VERY important, get a tranny cooler. If you do all that, your tranny will stay cool, shift firmly and last longer.
** Edit, even if you do nothing at all, atleast get the tranny cooler and pan. You will thank me in the long run. **
