#16
Re: questions....
The sensor at the top of the tank is the one that sets of the add-coolant light. If the sensor is shorted by having that bare wire it would probably set of the add-coolant buzzer/light.
Have you bleed the cooling system yet? If not then that woudl be a good place to start. Make sure you have the heat on full and if possible have the front end of the car raised in the air to help the movement of air. I wont go over the beeldiong process as it is quite simple and fron the sound of it you could do it with no problems. The koyo is worth it, it will keep your temps much lower when you are pushing the car. I currently run one but i may be getting something a bit bigger and better, gunna need the x-tra heat :P
![]() Dont drive faster than your angels can fly |
#17
Re: questions....
nopistons.com
and rx7club.com are rotary communities with lots of information, if you need help or you want to buy something do it on either of those 2. i buy stuff off of rx7club memebers all the time
RX-7 TII |
