Old 07-30-2005, 09:50 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: Manually Control Air/Fuel Intake Values.
the director where I work has a WRX and he has a 2 stage ecm... basically another ECM wired into the original ECM. the 2nd one is calibrated for performance. when he flips the switch you can see the additional smoke from the exhaust because it runs lean. flip it again and he's back to the original ecm. this is more benficial for him because he has a turbo and he has increased the boost to 16lbs.... and he has a free-flowing exhaust.
on a naturally aspirated 3.1 i don't think the slight gains are significant enought to justify the expense. I say forget about it and use laughing gas if you want a "performance switch."
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 07-30-2005, 03:04 PM
Viper_Storm's Avatar
Viper_Storm Viper_Storm is offline
Send a message via AIM to Viper_Storm Send a message via MSN to Viper_Storm
Re: Re: Manually Control Air/Fuel Intake Values.
who the hell is talking about a 3.1? we are talking about ls* engines.
All Throttle, No Bottle!
Torque Makes You Go... FAST!
Horsepower Is For Braggin Rights.
Money talks, But all mine ever says is Goodbye
~Viper
"twospirts" / "TS" - Definition: Obsolete
Old 07-31-2005, 12:51 AM
whoops... brain glitch. nobody mentioned engine size... so I mistakenly assumed we were talking about the 3.1 i read about in another thread. i didn't catch my mistake.
but even still, optimizing your A/F ratio will make your engine run smoother... but if you go to far and run lean, you will lose power. without some mode of adding more air along with the fuel (i.e. forced induction, nitrous) I don't see a significant gain.
Old 07-31-2005, 06:08 AM
i did mention that it was ls* engines up above, about 2 posts before you said something about 3.1. also it will be forced induction, turbo... but the problem is if im pushing 600+ hp to the wheels (i can see this happening, maybe) i want to be able to lower the air / fuel intake levels so that when im sitting in bumper to bumper traffic i dont run out of gas. but i also wanna be able to crank it back up when i need it... lol, like am i about to race? crank that shit up, am i just out crusing? crank it down.
~Viper
Old 08-01-2005, 03:40 AM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
i had a carbed car before and I leaned the Q-jet so much for emissions that it was hard to run the car while the engine was cold, but then fine (no lean knock and it had power too)
305 Cutlass Supreme,stock rebuilt Q-jet
My fuel estimates: lean 18liter/100km
poor perfomance
normal (a bit rich) 25Liter/100km
fast
see the difference now
So when you rebuild the carb think economy too
Old 08-01-2005, 09:57 AM
I'll try to remember to ask him how his works. He has an electronic blow-off valve that changes the max level of boost and fuel map when he flips the switch, or he just runs lean without changing the level of boost when he turns the switch off.
I'll ask him.
Any real performance shop that programs ECMs should be aware of this process. they should be able to tell you exactly what you need. Essentially all it is, is a blow-off valve that holds the pressure to a higher limit and a piggy-back/stage II ecm.
