Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 08-04-2005, 04:07 PM
Kilroy101 Kilroy101 is offline
Re: Fuel System Help
I checked the ignition switch and it is good too!
This thing is really pissing me off.
Old 08-05-2005, 12:19 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
How did you check it?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-05-2005, 02:21 AM
I used a circuit tester on the feed side and then on the supplied side with key off, on run and then on accessory.
Old 08-05-2005, 02:30 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Fuel System Help
Ummmm.....
That is not how you test it.
Just replace it, I can almost guarantee it is your problem.
Old 08-21-2005, 08:33 PM
I have replaced the following; both light and pump relays, fuel pump, ignition switch (key cylinder and column switch). I took the fuse panel out and cleaned the bulkhead connector (both sides) and the fuel pump still wont activate.
Old 08-23-2005, 06:59 PM
recncru1 recncru1 is offline
oil pressure/fuel pump switch.LOcated in the bak of the engine by the firewall.Its about three to four inches long with a wire clip.Three wires.
To the right and below the distributer.It screws into bloke below the intake manifold. THe oilpressure switch cuts the electricity to the fuel pump off when it thinks there is very little or no oil pressure.Keeps the engine from blowing if oil pressure dorops.I hope this helps.LEt us know.
