Old 08-01-2005, 11:29 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 95 Blazer sometimes won't start
Did you use a new upper plenum and EGR gasket when you replaced the CPI and EGR valve?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-02-2005, 02:44 PM
95Blazed 95Blazed is offline
All new gaskets installed, I followed all factory torque specs.
Old 08-03-2005, 12:27 AM
BlazerLT's Avatar
AF -Advisor
check your fuel pressure with the key on and the engine off.
Old 08-14-2005, 10:28 PM
Ok, replaced the cpi, the nut kit, put on a new coil, icm, cap and rotor, new plugs and rotor, replaced the sending unit, the fuel pump is good, changed the egr, and still have the same problem, truck runs fine when it is cold and hasn't ran for awhile but once it warms up it starts cutting out around 2-3 rpm and then it will die and not want to start back up. Sometimes it won't start if you shut it off until it sits for a few hours. Oh yeah changed the plug wires too. HELP!!!!!!!!!!!!
Old 08-14-2005, 11:30 PM
Will a stuck thermostat cause this? I remember when i bought it the guy said it was leaking and he fixed it before I picked it up. Maybe he got silicone happy. I have noticed some fluctuations in the temp. quage, but it never has got really hot. However the first time it did this dying and not starting it sat for like 4 hours and the motor still felt warm when I got there to work on it.
Old 08-15-2005, 01:30 AM
BlazerLT's Avatar
AF -Advisor
I'm thinking your cat is completely plugged from the fuel leaking from the old CPI injector.
Do you hear any rattling from under the truck?
Old 08-15-2005, 04:15 PM
No rattling, I already thought of the cat and cleaned it. I bought a new thermostat and temp sensor, will give them a whirl and see what happens.
Old 08-16-2005, 03:20 PM
I don't know, I put in new stat and temp sensor and no change, truck warmed up started its bogging and cutting out and but I could get it started back up 9 out of 10 tries......If I give her throttle real slow it revs fine, if I hit the pedal it bogs and cuts out. Maybe cat is still plugged? If it was the cat wouldn't it do this when it was cold and not warmed up though? It starts all this when the blazer starts to get warmed up and gets worse the hotter it gets or if it is really hot outside.
Old 08-16-2005, 08:14 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: 95 Blazer sometimes won't start
How can you clean a cat convertor?
Old 08-16-2005, 09:19 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: Re: Re: 95 Blazer sometimes won't start
By backwashing it with liquified dog... (listens to the crickets chirp)
Yeah, that line caught my attention too a day back and I just could not bring myself to say anything. At least, not anything immediately constructive. You CAN'T clean a catalyst - only replace. At least, that is true about automobiles. Industrial catalysts can be cleaned by chemical processing, but these are the cats that control smog and acid emissions from factory smokestacks... different world altogether.
Old 08-17-2005, 08:04 PM
Its a technical process that involves a ratchet, hammer and a 3foot chunk of exhaust pipe slightly smaller than the inlet and outlet on the cat........ BY the way, the cat looked clean to me, was NOT at all carboned up, I would say it was replaced not too long ago. Which brings me back to the d@*n cpi, maybe the one I got is defective or something. I have noticed when this started my oil pressure is lower at idle, like around 30, but goes up on acceleration to where it always has, but it used to idle about 40-50. I think it is getting a little gas in it and thinning. Will a bad cpi start fine after the blazer has sat for awhile, then run fine till it warms up and then make it bog, not want to rev over 2,000 rpm, sometimes die and then be hard to start until the vehicle has sat several hours? Cold starting and running not a problem just starts its crap after it warms up. I have always done all my own mechanical work and have never had a problem as baffling as this. My 99 xtreme never gave me this s#*t! Thanxs for trying to help all!
Old 08-17-2005, 08:10 PM
By the way BlazerLT I know some give you a hard time about always saying the cpi, but from what I have heard from other owners and even dealer mechanics, this is the most common problem on w code 4.3's.
Old 08-17-2005, 09:38 PM
BlazerLT's Avatar
AF -Advisor
Yea, people think I go on and on about the same thing.
I know the problems with each year and I tell them most common problems.
If anyone has a problem with that I could care less. I am only trying to help. They just see the fact that I help almost everyone and when it comes to the same W engine, we already know the problem in most cases. If someone has a problem with me cutting to the chase and telling them where to look, meh, let them go and spend 1000s trying to fix it if they know better.
Also, you do know you have a pre and post cat O2 sensor so you can't remove everything in the cat and expect it to run properly.
Old 09-15-2005, 03:58 PM
Its fixed! The first cpi I put on was no good, leaking like a faucet. Went and got a new one and no problems now. Blazer running better than when I bought it! Thanks Lt
Old 09-15-2005, 07:47 PM
BlazerLT's Avatar
AF -Advisor
No problem, no go and get your oil changed ASAP and get a new set of plugs in that engine.
DON'T KEEP ON DRIVING WITH GAS SATURATED OIL!!!!
