Old 08-03-2005, 11:46 AM
dycksonjl dycksonjl is offline
Thanks for the info. What are the square pegs loacted by the inlet valves for?
Old 08-03-2005, 12:09 PM
89ltd 89ltd is offline
Re: R12/R134 conversion
i have no idea, never touched them
Old 08-03-2005, 12:36 PM
Thanks for the Info. What are the post/square pegs along side the inlet valves used for?
Old 08-03-2005, 04:03 PM
So what you're saying is...when I hook up to the low side the hose and new can will prevent any gasses from escaping?
Old 08-03-2005, 08:57 PM
the valve opens in the same way as when you put air in your tires. You would have to describe your kit, did it come with a fitting to screw on to your low pressure hose? and then a quick disconnect?
Old 08-04-2005, 08:46 AM
No quick disconnect. THe hose screwed on the fitting. I connected the hose to the can then to the fitting. Punctured the can and turned the A/C on. Nothing happened. No flow. Maybe I'm missing a part of the kit. What you're saying sounds right. I'll look for the fitting and quick disconnect. Thanks.
Old 08-04-2005, 09:57 AM
when you screw in the tap that punctures the can it also seals the can closed, so then you have to unscrew the tap and the gas will be drawn in slowely, putting two cans in should take about an hour or so.
Old 08-04-2005, 09:59 AM
if after the can still has gas in it, you have to keep the hose kit on the can and close the top valve before disconnecting it from the low pressure side fitting.
Old 08-05-2005, 01:24 PM
I bought a 134 retrofit kit yesterday to see if that would fix my problem. Followed all the instructions and the system will not take any freon. I did notice that the aux fan didn't turn on and I never heard the compressor engage. Is there a low pressure switch the shuts down the compressor? Is there a way to override it? How do I recharge my system!!!!!!
Old 08-05-2005, 01:28 PM
there is a way to get it running, if you give me a minute...
Old 08-05-2005, 01:37 PM
you need to jump the wires on the low pressure cylcing plug, do you know where it is?
Old 08-05-2005, 02:04 PM
what size engine , year?
Old 08-05-2005, 04:58 PM
'92 4L
I jumped the switch (by the sight glass) and the compresser came on. It still wont take any freon!!!!! I dont know whats going on!!!!!
Old 08-05-2005, 05:15 PM
did you open the valve on the can after hooking it up???
Old 08-05-2005, 06:46 PM
I opened the can. I have a meter on the hose and it shows over 100lbs.
