Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 07-20-2005, 03:58 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: ZC Generations
You'll run into a problem with the CRX flywheel. The hole in the center for the guide bushing is larger than the input shaft on the Integra transmission. You'll either need to have a bushing made, or use an '86-'89 Integra flywheel. If you don't, the input shaft won't be supported and eventually you'll blow the tranny. If you use the Teg flywheel, you can also use the Teg clutch, but it's smaller. I've got a spare Teg flywheel that you can have if you decide to go that route.
Good to know about the wagon clutch!
Old 07-20-2005, 11:31 PM
KrisSmithRocks's Avatar
KrisSmithRocks KrisSmithRocks is offline
Send a message via AIM to KrisSmithRocks
Re: ZC Generations
well what i'm noticing about the hole in the flywheel is that if anything the hole is a little bit too small. I'm gonna mic it later and compare to the number i get from the integra i think what you are thinking about is the later gen flywheel. It is designed for a pilot bearing but the imput shaft on the tranny is too big for the pilot bearing so i was originally going to go that route and use an Si clutch but what i discovered was that the Si pressure plate hits the bell housing in an inconvienient way. Someone else on the internet discovered that too i don't remember who it was though. So i'm not sure maybe i have a different flywheel than i thought it did. i'll let you know
89 Honda Accord LXi 2dr- Daily driver SOLD (sniff sniff)
89 ED CRV... soon to come GSR head, ARP studs top and bottom, T3/T4 at about 6psi ... it's quick...
89 ED DOHC ZC
Old 07-21-2005, 01:27 AM
lxndr's Avatar
AF -Advisor
Re: ZC Generations
Yep, I'm thinking of the 2G CRX flywheel, I didn't know the 2G ZC flywheel was different. I'm still learning some of this stuff too, that's why I'm interested in how your swap turns out.
Old 07-21-2005, 02:50 PM
k if anyone is intrested i found the other guy that did it i read this article on the internet...
http://www.muller.net/sonny/crx/swap3/index.html
Then i made a bushing and mocked everything up and discovered it hitting then i read the next installment
http://www.muller.net/sonny/crx/swap4/index.html
and realized that i wasted some time.
89 ED DOHC ZC
Old 07-21-2005, 03:16 PM
hey lxndr i've got a favor to ask you... so i was looking on NAPA's website and i noticed that the part number for the integra flywheel and the CRX flywheel are different so i was woundering what dimension is different i was hoping that you could measure the one that you have and let me know about the step height and hole dia and stuff like that because i can get one from napa for the same price that it would cost me to machine mine so i'll probably just go that way but i want to make sure i get the right one...
89 ED DOHC ZC
Old 07-21-2005, 03:38 PM
lxndr's Avatar
AF -Advisor
Re: ZC Generations
I'll see what I can do. They'll just be rough dimensions since I broke my calipers (Rrrggghh!).
Just to give you some comparison, I recently had my flywheel resurfaced and lightened for $90.
Sonny's site is a great source for information! I was even able to see his car in person! I still contact the new owner from time to time for information. EVERYTHING that was done to this car was documented, so I also use Sonny's site as a guideline. BTW, his CRX is a little more rough than the pictures show.
Old 07-21-2005, 10:03 PM
Re: Re: ZC Generations
i know a guy who runs a machine shop and he does them for me for 35 after hours... but i can get a brand new one from NAPA for 40 so as far as lightening it goes i'm think that i'll save that for when i get a better clutch then stock. as for now i'm just trying to get it on the road, then flywheel and clutch, then turbo.
89 ED DOHC ZC
Old 07-21-2005, 10:59 PM
so anyway if anyone is intrested i cleaned and painted my engine bay the last few days so i'll post some pics of during and after below
I used a spray on truck liner with some texture and i think it came out pretty well. I still have some touching up to do though
after
so anyway i think that it turned out pretty well let me know what you think
89 ED DOHC ZC
Old 07-21-2005, 11:49 PM
lxndr's Avatar
AF -Advisor
Re: ZC Generations
You missed a spot.
Just kidding!
Keep the pictures coming, we all love pics!
Looks good!
Old 07-25-2005, 10:49 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: ZC Generations
looks good
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 07-25-2005, 11:13 PM
Re: ZC Generations
thanks for the support i should be able to get the flywheel and pressure plate on Friday so i should at least get the motor in and hanging this weekend.
89 ED DOHC ZC
Old 07-26-2005, 02:09 AM
Re: ZC Generations
just thought i'd throw this out to i'm looking for some integra stuff that i can swap in eg. knuckels, front and rear suspension and brakes, etc. everytime i go to the pull a part there arn't any there so if anyone has any ideas about where to score some of these parts let me know.
89 ED DOHC ZC
Old 07-26-2005, 02:33 PM
lxndr's Avatar
AF -Advisor
Re: ZC Generations
Are you talking about the Pull-A-Part in Lynnwood? I'm there about 2-3 times a month, I can let you know when they've got a Teg.
Also I just received another extra Teg flywheel, that has been resurfaced. Let me know if you need it. I bought a used ACT clutch from someone on RPR (only 300 miles on it), and he sent me the flywheel too. Since I've got a lightened flywheel, I don't need it.
I'm such a DOLT! I forgot to get you the measurements for the flywheel!
Old 07-26-2005, 02:36 PM
yea i'm talking about that one i think it's either Lynnwood or Everett it's right across the street from the bent bike motorcycle place. anyway yea i try to go like once a month or so but if you could let me know that would be great.
89 ED DOHC ZC
Old 07-26-2005, 02:43 PM
lxndr's Avatar
AF -Advisor
Re: ZC Generations
OK,
Here are some rough dimensions for the flywheel. I stomped on my calipers, so I took these with an acurate tape measure.
Overall diameter (including ring gear):
11 1/8"
Clutch surface diameter:
8 3/16"
Guide bushing hole:
An ass hair over 3/4"
Hope you can still use this info!
